Page 17 of 18 FirstFirst ... 7131415161718 LastLast
Results 321 to 340 of 359
    Mar 2016
    #321
    I send a PM syo. Gusto ko sana magpa glass coat next week if possible. Thanks.
    Sent from my HUAWEI MT7-TL10 using Tapatalk
    #322
    Quote Originally Posted by saiyan0728 View Post
    Hi Clavel. How much for Ford Everest 2016. Thanks.
    Pls. Call/Text for faster transaction
    #323
    Quote Originally Posted by wutangclan_79 View Post
    Magkano for fortuner 2016
    Sent from my Starmobile Knight Vision using Tsikot Forums mobile app
    Please Call/Text for faster transaction
    Mar 2016
    #324
    Quote Originally Posted by CLAVEL3699 View Post
    Kindly PM me your contact. Thanks.
    #325
    7 WAYS TO RUIN YOUR PAINT WITH OUT KNOWING IT
    Keeping your car looking good isn’t just a matter of enhancing its resale value, although that’s important too, it’s also your car’s only line of defense between the sheet metal and the elements. You already know parking lot dings, gravel roads or an angry ex can ruin your car’s paint in the blink of an eye, but a lot of things out there can do just as much, if not more, harm to the exterior of your car.
    I recommend keeping a good coat of wax on your car, if you cannot afford a Glass Coat. Not only does it keep it looking pretty, it helps prevent most paint damage, or at the very least, buys you some time to get your car washed. I also recommend keeping a bottle of quick-detail spray and a microfiber cloth in your trunk. As you’ll see, a lot of these common problems can be prevented with a quick wipe of this solution.
    THE SOURCE: TREE SAP
    The Problem: Ancient peoples used tree sap as glue for a good reason.
    The Solution: Bug and tar remover, mineral spirits, clay bar treatment
    Just wiping sap off when it’s still gooey only smears it around a larger area. Instead, get a bottle of bug and tar remover from your local car parts store, and use it as directed. If the sap dries, mineral spirits can dissolve it, and remaining residue will come off with a clay bar treatment. Just be sure to wax the car after you’re done.
    THE SOURCE: THE GAS PUMP
    The Problem: Spilled gasoline
    The Solution: Don’t top off, and clean up accidental drips
    Times are tough, but “topping off” your gas tank and accidentally letting it overflow is a sure fire way to damage your car’s paint. If left alone, gasoline will leave a stain on your car’s finish that’s nearly impossible to get off. If you do happen to spill gas by accident, the best solution is to grab a bottle of instant detailer and a good, clean microfiber cloth and clean up the gasoline before it does any harm.
    THE SOURCE: FINGERTIPS AND MISCHIEF
    The Problem: Writing or rubbing on dirty paint causes permanent marks.
    The Solution: Keep your car clean.
    We’ve all seen “wash me” written on a car’s finish, but the well-intentioned tagger actually just made things worse. Dirt acts like sandpaper when it’s dragged across paint, and it can make the marks last long after the dirt is gone.
    Get yourself a long-handled duster and wipe down your car every day to prevent accidental sanding. If it’s too late, most small scratches come out with a polish or scratch remover. Just always be sure to clean the car well before waxing or polishing.
    THE SOURCE: YOUR MORNING COFFEE
    The Problem: Coffee and sodas contain acids that can etch your clear coat.
    The Solution: Wash it off immediately
    Driving off with your coffee cup or soda bottle on your roof isn’t just a day-ruined; it can ruin your paint. Many beverages are acidic, and since any acid can hurt your car’s finish, you’ll want to get it washed off as soon as you can. Letting it sit will only give it more time to do damage, and letting it dry will only make it harder to get off later. If it’s a soda, or if you take a lot of sugar in your coffee, then you’re going to be dealing with a sticky residue in addition to corrosive chemicals. If you can’t hit a car wash, then break out your bottle of quick detailer and your microfiber cloth and wipe it up.
    THE SOURCE: DIRT ON YOUR CAR-WASH TOOLS
    The Problem: Unseen dirt can scratch
    The Solution: Keep an extra mitt handy
    Washing your own car can be fun, but a common mistake can cause more damage than you think: dropping your sponge. Even the finest, most expensive microfiber wash mitt on the market can be ruined if it touches the ground. The bits of grit and sand it inevitably picks up can’t be entirely washed off, and you’ll have swirl marks and other scratches before you know it. The solution is to never drop anything. But if you’re like us, it’d be best to keep a spare washing mitt or two on hand to avoid the resulting expenses from car detailing or repainting.
    THE SOURCE: AVIAN DIGESTION
    The Problem: Bird poop is acidic
    Bird poop isn’t just unsightly. It’s also acidic. Just look at the number of ruined marble statues in pigeon-infested cities and you’ll see what we mean. Not only that, but birds eat seeds and bits of gravel that can scratch your paint.
    The solution is to wash bird droppings off as soon as you see them. Use a bottle of quick detail and a soft microfiber cloth to wipe it up. Be sure to use a lifting action, since you don’t want to grind any grit onto your paint.
    THE SOURCE: BUGS
    The Problem: Bug guts are acidic
    The Solution: Get to the car wash
    You’re heading home from a road trip when suddenly the eighth plague of Egypt strikes, with thousands of bugs splattering your windshield. But just cleaning the windshield isn’t enough. Bugs are surprisingly acidic, and if you do hit a swarm, don’t let the bugs get the last laugh as their remains slowly etch your paint. Wash your car as soon as you can with a good car wash solution, and for the more stubborn guts, use a bug and tar remover.
    Attachment 32743 Attachment 32744
    #326
    POMPONAZZI PILIPINAS Exclusive
    FORD MUSTANG 5.0 - June 01, 2016
    Detailed and applied our POMPONAZZI Quartz Glass Coating - 880xx
    4 Days BACOLOD CITY Exclusive
    PREPARATION
    Attachment 32754
    1 DAY CURE
    Attachment 32755
    #327
    BACK TO BACK: June 01 and 02, 2016
    FORD MUSTANG 5.0 and SUBURU STI
    Attachment 32757 Attachment 32758
    #328
    SUBURU WRX STi - June 02, 2016
    Attachment 32797 Attachment 32798
    #329
    TOYOTA FJ CRUISER - June 06, 2016
    Detailed and applied our POMPONAZZI Quartz Glass Coating - GT1
    DONE IN ONE OF TOYOTA BRANCHES
    Attachment 32800
    Attachment 32801
    Attachment 32802
    Jun 2016
    #330
    Good day Sir,
    Magpa estimate ako ng glass coat ng 880xx para sa Volkwagen Beetle, Model 2001 (Silver color).
    Please PM me.
    Thanks,
    #331
    Quote Originally Posted by Friedlander View Post
    Good day Sir,
    Please PM me.
    Thanks,
    Sir Kindly call/text for fast transaction.
    #332
    TOYOTA RAV 4 - June 13, 2016
    Attachment 32895
    Attachment 32896
    Attachment 32897
    Attachment 32898
    #333
    FORD EXPLORER - June 14, 2016
    Attachment 32899
    Attachment 32900
    Attachment 32901
    Attachment 32902
    #334
    HONDA JAZZ 2016 - June 21, 2016
    BEFORE (Above Picture) AND AFTER (Below Picture) Effect
    Attachment 32941
    #335
    HONDA JAZZ 2016 - June 21, 2016 (BALSO CLEANING)
    Detailed and applied our POMPONAZZI Quartz Glass Coating - 880xx last April 2016 (2 Months Ago), now received a BALSO CLEANING
    Attachment 32942 Attachment 32943
    Attachment 32944 Attachment 32945
    #336
    POMPONAZZI SOUTH KOREA Exclusive
    PORSCHE MACAN GTS - June 16, 2016
    Detailed and applied our POMPONAZZI Quartz Glass Coating - 880XX
    Attachment 32946 Attachment 32947
    Attachment 32948
    #337
    Pomponazzi Education Center South Korea
    Attachment 32952
    #338
    MITSUBISHI MONTERO - June 23, 2016
    Attachment 32953
    #339
    FORD EVEREST - June 25, 2016
    Attachment 32969 Attachment 32970
    Attachment 32971 Attachment 32972
    May 2016
    #340
    Thank you Clavel and Team for the home service.
    Staff are very polite, professional and knowledgeable with their product.
    Good Customer Service: updates on staff whereabouts, monitoring of service / application and after service inquiries were done.
    Even the owner called up to check if his staff and their service are good.
Glass Coating Paint Protection
