Page 1 of 2 12 LastLast
Results 1 to 20 of 43
    May 2011
    weekly ba ang elevo water mark remover?
    pagsinamahan ba ng rain x or any water repellant weekly pdn both? or repellant nlng
    May 2011
    ay tsaka yung headlight and tail light ba may nilalagay kayo para hindi manilaw? thanks..
    yung elevo watermark remover you only use kapag may watermark. but you need to seal yung the glass after you remove the marks else madali bumalik. you seal the glass with rain clear gel. sa blade may tinda sa sacket.
    sa headlight naman, I use KSG to seal it
    May 2011
    okay thank you.. =)
    Jun 2007
    I just saw the "paste" elevo watermark remover.
    meron syang grit and abrasives... parang compound.
    Oct 2009
    effective ba yang elevo water mark remover?
    Oct 2004
    Quote Originally Posted by Ginnova View Post
    t
    thanks for this info mga sir... i am really looking for something para sa windshield, lalo na sa likod... wala naman kasing wiper...
    how much is this sir sa blade?
    yung nasa sachet P88 pesos lang.
    Aug 2010
    ma try nga din. pinang alis ko kasi 3m scratch remover sa hard water marks, okay naman ang result medyo tiyagaan nga lang sa pag tanggal.
    Oct 2004
    thanks sir... walang stocks sa Festival...
    Feb 2005
    Just got a pack of Rain Clear Gel with Rain Scrub glass cleaner... let see if its good. Meron rin akong nakitang yung cleaner and repellant all in one spray... forgot the exact name pero from glass science din. got the aforementioned pack na lang kasi mas tatagal.
    Oct 2015
    So pwede po pagpatungin yun gel tapos water repellant?
    May 2011
    Yes,might be the wiper.. the elevo worked for me with n0 problem at all.. =)
    Mar 2004
    Same here, Elevo works well. You might want to try Glass Scrub, removes dirt and grime also, got this from True Value at Park Square.
    May 2010
    Used this yesterday both on frond and "back" windshield and very effective. sobrang linaw na ng salamin nawala yun mga libag. i made sure na ilang beses ko pinunansan un salamin ng MF cloth to totally remove the chemical after eapply. pansin ko lng pag 1 or 2x mo lng sya pahiran makita mo pa din na may rainbow. un sa likod na salamin lang tumutog na un wiper prang d sya nagslide maayos.palitan ko na lng or ulitin ko linis don pag wala na ulan.
    recommended tong product na to based on my experience.
    guys ensure to top-up your newly cleaned glass with a repelant para hindi bumalik ang watermarks. rain clear gel is recommended.
    which is better? the elevo liquid or the one in paste? i had my windows polised sa bigberts kaso after 3mos grabe uli waterspots
    May 2011
    Wala na un rain clear gel sa blade di ko natry sayang haha binili ko na lang un rain repellant ng blade 88php nakalimutan ko may rain x pala ako sa bahay sayang haha
    Mar 2005
    Sa ace meron pa din ata ng rain clear.
    Jun 2015
    Just sharing.
    Maganda kinalabasan ng paggamit ko nitong Elevo water mark remover. Ginamit ko rin sa side mirrors at blindspot mirrors. Sabi sa box do not use on side mirrors pero yung nasa picture ay may heat coils na side mirror so I think the prohibition is not to use it when your side mirror is warm (same as with the windows). No signs of hazy spots anywhere and my old wipers now glide smoothly across the windshield.
    Tapatalked
Elevo Water Mark Remover and Rain X
