got this from C! Magazine.
share ko lang..
Do you know that the most hi-tech airconditioners, air filters and water purifiers use charcoal cleaning, for all of its black and glory, can be used to filter out air and water for it to be suitable for human consumption. What makes the charcoal work is not the black substance of the charcoal itself, but the element that makes the charcoal effective - carbon. One of the most basic elements in chemistry, Carbon acts as a neutralizer in removing odor, germs and even solids. It is for this reason that some cigarette manufacturers started impreganating charcoal into cigarette filters to remove toxins and lessen the harmful chemicals such as carbon monoxide, etc.
You can harness this filter effect:
Get a PRINGLES potato chip can, fill it with charcoal, puncture the holes in the top with a nail and place it under the seat of your car. You'll notice that in a couple of days, your car will smell less putrid or less "plastic-like" as the carbon of the charcoal inside the perforated can absorbs the odor and moisture inside the vehicle. It is recommended that you discard and replace the charcoal at least once a month to ensure its effectivity.
