mates,
i'm planning to paint the rear drum brakes of my ride. medyo napansin ko kasi na may konting kalawang.
should i be careful of any moving parts in the brake system that shouldn't be painted?
thanks.
mates,
thanks.
Baklasin mo na lang kung brake drum para makasiguro ka na di mapipinturahan yung hindi dapat. Use high temp spray paints, para di mabakbak agad ang pintura.
Pero mas makakamura ka sa steel brush at liha, kung mababaw na kalawang lang naman ang tatanggalin.
good advice Ungas...DT, you will need the steel brush and light sandpaper anyway, because if you paint the brake without removing the rust and completely 'scuffing' the surface, the paint will peel and it will look even uglier than the rust itself.
can anyone recommend where pwede pa paint ng drum brake? pangit tignan may kalawang. no time for DIY.
sa may welcome rotonda ako nagpagawa. sa N. Ramirez. tapat ng dating kuwatog. meron dun expertise nya un drum brake
does anyone know kung meron sa south area? and magkano usually inaabot painting? usually red ang nakikita ko, pwde din ba kayang black or silver?
tanong nyo sa kilala ninyong pintor ng sasakyan ang price at para masmaganda ang gawa. sa masmalapit sa lugar niyo para nakikita ninyo at madaling ibalik kung meron problema.
Kung tipid mode Bosny spray paint ayos na iyan . Kung may kalawang lihang bakal at steel brush lang katapat niyan kung gusto mong mas makintab Bosny clear coat pagkaqtapos mong pinturahan.
mahal naman kung 500 per drum brake. sa DIY baka less than 500 lang magastos for both side pa.![]()
