Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Jun 2005
    Hanggang anong layer ang tinatanggal ng rubbing compound?
    Nagpa-wax kasi ako ng kotse, kaso yung tao, rubbing compound ang ginamit!!! Napagkamalan daw na wax.
    Any suggestions?
    Thanks!
    given with enough time and effort, you can rub all the way to bare metal.
    Quote Originally Posted by jarx
    Any suggestions?
    Thanks!
    araykupo! dapat sagot yan nung nag-wax!
    Dec 2003
    depende kung gaano kalakas ung waxer hehe
    Ano ginawa mo dun sa tao? i guess same procedure ng pagwawax yun ginawa nya so baka tangal na yun clear coat mo. Ginamitan ba ng polisher? Kung ganun, balikan mo yun hayup na yun ang singilin mo ng 2500 tapos pa spray ka ulit ng clear coat.
    Mar 2004
    Damn!
    Have your paint inspected by a good painter / detailer. They can check whether or not your clearcoat is gone.
    Jun 2005
    Hindi naman nagamitan ng polisher...
    Pinalagyan ko nalang kaagad ng wax, pero ipapatingin ko nalang din para sigurado
    Salamat
    anong rubbing compound ang ginamit?
    anyway, buong car ang na-apply?
    Jun 2005
    hindi ko sure kung anong brand ng rubbing compound. yup, buong car ang nilagyan. Napansin ko nalang after niya ginawa at hindi makintab, tananong ko kung bakit. Sabi, "Sir, madami naman ako nagamit na wax" (sabay pakita sa akin nung rubbing compound)
  10. #10
    hehe, nagmalaki pa teka san ka nagpa "wax"? mukhang sa tabi tabi lang, obviously if he can't decipher a wax from a rubbing compound paktay na tsikot mo hehe
    Jun 2005
    sa bahay ko lang pinagawa. tinuruan ko na dati yun sa isang kotse. so expectation ko is alam na niya kung paano gawin. inabot ko na yung car shampoo at wax, pero nakita siguro niya yung bote at gumawa ng kwento na baka nag transfer ako ng wax to the bottle. kaso, rubbing compound laman ng bote so ayun...
    Paktay talaga. Just the thought of it happening to my car brings shivers to my spine. Ouch.
    tapos sabay banat... "Sir, wax-in wax-out yung pag apply ko ng wax"
    tsk tsk, aray ko po
    May 2005
    If he rubs the rubbing compound the way he use the wax i dont think he murdered your paint or clear coat, and hindi naman niya ginamitan ng polisher (thank God).
    kaya pa yan actually. dull na ba ang paint? mahahabol pa yan sa polishing kung buhay pa ang CC mo.
    best bet mo is to have that assessed by a Pro Detailer para maka-siguro ka. then kutusan mo sa ulo 'yung gumawa nyan.
    Jun 2005
    sana nga hindi masyadong naubos yung clear coat... makapal pa naman "dati" dahil mag 1 year palang yung kotse
    and siguro naman hindi vigorous ang pag-apply nya ng Compound..
  19. #19
    You can do a test to see whether your clear coat is still there... I just forgot how
    depends sa paint actually, kung paint mo pre-mixed ang clear (single stage), di pwede gawin yung standard CC test...
    Basically get a white cloth, dab a little polish or compound and rub an inconspicous area sa exterior ng car na medyo malakas, if the paint transferred to the cloth, walang clear or walang hiwalay na clear coat.
    based on your post, I think nagmarr lang yung paint mo medyo, you'll need to manually remove the compound using a polish to remove the fine scratches created by the compound then rewax. I don't think natanggal ang clear kung hand applied na di naman "kinuskos" sa lakas.
Rubbing compound
