Quote Originally Posted by Hardinero View Post
paps, parang ok itong spit shining ah...kaya lang nalilito ako sa explanation nila..
baka you could explain it in laymans term..
AFAIK, applicable lang ang spit shining sa carnauba-based wax, not sure though kung pwede sa mga synthetic polymer...
anyway, the principle is to "avoid" the wax's chemical (neutralize the solvents) to disturb, remove and/or mix with the existing layer of wax, thus, you use a "cold" (about to be frozen) distilled water or QD to mist the surface first before applying the new layer so the newly applied wax will almost freeze, then you wipe/buff it off until the wax and water (or QD) disappear...
it's a tedious process, and i'm not "satisfied" with its effect... i'd rather use the same product lines, as the manufacturers guarantee that their products "blend" well with each other... HTH...
