That light green long button on top of the handle, you'd just press and hold and the spray will go on continuously, if tinatamad ka, you may press the little gray button for the spray to go continuously without holding the light green button... parang lock. Then to unlock, just press the light green button again
Tapos pag wala na pressure, pump ulit... super ejoy ko mag waterless wash with ONR everytime i use this... wala nang spray-sparay, one hold then release na lang...
tignan ko results ni doc bombit if he makes it foam better... otherwise, I'll stick to using mine for the waterless wash
also mas highly recommended ko ung ACE (red and white) than this green one... the ACE Branded Pressure Sprayer has metal parts, whereas, for this model, plastic and rubber... and most of all, masmura ung ACE.
