Page 29 of 79 FirstFirst ... 1925262728293031323339 ... LastLast
Results 561 to 580 of 1575
    Aug 2009
    #561
    Miss madkatz, kindly rate the OCW from 1-10.. Shine, duability, and beading..
    Thanks
    for shine i would put at 8 both in terms of depth and gloss as for beading it really doesn't bead as much but it does sheet very well, this is supposed to be a car wax not really a booster wax as most people use it, its already damn good as a pure wax, its ever better at keeping waxes and sealants alive when used as a booster, really ideal for multiple layers maintenance
    Feb 2007
    #562
    Quote Originally Posted by raine
    sa mga detailing experts patulong po,
    meron na akong turtle wax rubbing compound, turle wax polishing compound, mothers step2 sealer and glaze, mothers step3 carnauba wax, and carlack68 long life sealant.
    ano ang magandang pagkasunod sunod ng mga product na ito para ma maximized and benifits sa protection and shine ng paint.
    thanks
    *raine - It would be easy if you'll let us know what's the condition of the paint. Post a picture perhaps?
    #563
    Quote Originally Posted by madkatz View Post
    only the ONR is 32oz there's no OCW thats 32oz, its the 17oz spray bottle, if you guys are really interested you could probably do a group buy from my BF, he might be able to match the price and give you some freebies anyways he's the official distributor of Optimum here in the Philippines
    +1 on this. Master would also teach you tips and tricks on how to use the items properly.
    Oct 2008
    #564
    Quote Originally Posted by raine View Post
    thanks
    generally, microfiber for everything is safest.
    most of these products will work, although some are less intuitive to use than others.
    major cut, use light arm pressure:
    set aside the TW compounds for jobs beyond scratch removers.
    no cut process: this will bury whatever contaminants that a regular wash can't remove, among other things. up side is that new contaminants will now be on the wax.
    1. mom's step 2 then step 3 or
    2. some do mom's step 2, Isopropyl Alchohol (IPA) wipedown, LLS, then mom's step 3
    for more about your products and related processes, read this thread and/or the earlier series.
    #565
    ok thanks, try ko yung advice mo.
    gagawin ko lang 3x ang LLS
    #566
    Quote Originally Posted by jmpet626 View Post
    Mga ilang applications kaya yung 17oz na bottle? Nag apply ako kanina sa Sta Fe ng OCW mga 1/4th nabawas sa 500ml na spray bottle eh. Normal ba to or masyadong madami pag lagay ko
    jmpet, medyo madami yata gamit mo Ang technique ko for spraying OCW is slow squeeze, and while squeezing, swipe your spray over the area (ex., left to right). You just need a very light mist over the area you intend to wax.
    For example, sa isang door ko, one spray across the top half, and another spray on the bottom half. Make sure lang na as your squeeze, you also move your hand so that the your squeeze will last the entire left to right movement. Gets ba? Ang hirap i-describe... hehe. Tingnan ko kung makagawa ako ng video
    Jun 2010
    #567
    Just follow the usual rule for waxes... apply as scarce as possible. To make it so, tama ung sabi ni doc, spray and swipe...
    just to give an idea... I use mine in between washing and had my OCW for nearly 2 months now... ung 500ml bottle ko, mga 1/5 lang ung bawas.
    #568
    Mga sirs RE: Soaking MF in water with vinegar, gaano po katagal ito ibababad? Kalalagay ko lang sa bucket with water/vinegar mixture. Hehe.
    Mar 2005
    #569
    Quote Originally Posted by bombitmd View Post
    Ok thanks nasanay siguro ako pag nag QD using ONR at DP rinseless wash & gloss. Wala kasi ako fine mist na sprayer ang gamit ko lang yung biogenic alcohol sprayer.
    May 2010
    #570
    ang NXT ba talagang malamya magbead??
    Mar 2005
    #571
    Quote Originally Posted by jed_015 View Post
    Compared sa collinite waxes mas malakas beading ng collinite.
    Oct 2007
    #572
    what do you mean by IPA wipedown?
    Mar 2004
    #573
    in other words, mas maganda collonite right?
    #574
    Quote Originally Posted by dbhollanda View Post
    Definitely.
    Mar 2005
    #575
    Compared sa collinite 845 vs NXT 2.0 parang same lang sila ng durability nung pinag compare ko sa Rav4 ko mga 2 weeks tinaggal since open parking. Malakas mag bead yung 845 pero maganda shine at slickness ng NXT 2.0 for me at may light cleaning ability na din yung NXT. Mahal nga lang nxt sa mall nasa 1.6k ibang sellers 1.2k. Depende na lang kung magkano mo makukuha yung NXT kung 700 to 800 pesos ayos yang NXT.
    May 2010
    #576
    May Cleaning ability??baka natanggal 476 ko kaya ganun..kasi pinatong ko sa 2 weeks old na 476 yung NXT..hindi naman ganun ka-bad yung beading..siguro nakumpara ko lang sa collinite kaya ganun..hehe..tska sa hood ko lang napansin na naging malamya yung beading..pero sa ibang parts..okay naman so far..
    Thank you sa mga nagreply
    Jun 2010
    #577
    Hi guys,
    My first can of 476 is almost empty. Now, I'm thinking of whether I'll get another one or buy 915 instead. Aside from the price(700 vs 1800 ), does anyone know their differences in terms of performance? Which one's better for black cars? Thanks!
    #578
    Tulad ng sabi ko sa inyo ni kent sa kabila, patungan niyo ng double coat Collinite 915 yan. Pagsa hindi na dinapuan ng dumi yan
    Sa bronze palang ibang klaseng kintab na kinalabasan, sa black niyo pa kaya :clap:
    Mar 2004
    #579
    yung sa kin 30 min is fine then banlaw ng tubig super lambot na ulit ng MF...
    Mar 2004
    #580
    ang collonite 915 ba e may cleaner ingredients or pure wax sya? kasi mas ok sa akin yung pure wax (walang cleaner) para pwede kong ipatong sa carlack twins?
    what about OCW -- pure wax ba ito or may cleaner ingredients?
Detailing Thread [For Newbies][continued 2]
