Results 1 to 20 of 1575
    Aug 2009
    Quote Originally Posted by franster View Post
    Oh. I forgot to mention this,
    I think I have used 3M Auto Scratch Remover often on some spot treatment, and I have the feeling that I abraded much of the layer of the clear coat (or I may be just paranoid). If you must know, I used a light pressure on the application.
    Should I provide a new layer of clear coat on those spot treatments? Or is the application of wax enough to seal the cured clear coat?
    check if the area for orange peel, if it still has orange peel or if its flat but looks like there's still a film on top, you're still safe
    Jul 2010
    Quote Originally Posted by madkatz View Post
    sorry for the ignorance, but does this orange peel literally orange?
    As what I have observe on the spots that i had applied with the 3M Auto Scratch Remover, the area looks dull and not shiny anymore and has swirls, but still up with the level of the surface of the coat.
    Aug 2009
    try to search orange peel on google
    Jul 2010
    Thanks. So it is called orange peel cause of it's texture and looks similar with the peel of the orange.
    well that's not my case actually. What I have observe and catches more of my attention is the dullness and lack of shine of the spot that I treated with 3M Auto Scratch Remover. Can waxing bring back its shine? or do I really have to use a polish?glaze?
    Mar 2005
    Polish need niyan like swirl X. Di talaga maganda finish ng 3m scratch remover masyadong agressive.
    Aug 2009
    im not saying that it was your case, but you were concerned about clear coat thickness and orange peels are a good indicator that you still have a thick clear coat left, usually when a car has orange peels now matter how small its basically a good sign that your clear coat is still thick and not yet damaged, conversely if a car no longer has orange peels you better stay away from using too much compounds and polishes where scratches removers are somewhat an in between product between the two, you have to use a polish, glaze will only fill them and after a few washes its basically gone
    so to sum it short checking for orange peel will really help to determine whether you need clear coat, whether you could still use scratch remover or polish or if its near the base coat already
    Jul 2010
    Any idea of how thick of clear coat was abraded using the scratch remover by hand using light pressure?
    Thanks for all your help.
Detailing Thread [For Newbies][continued 2]
