Quote Originally Posted by flakez View Post
jsut got my swirlx, tinest ko don sa isang kotse na puro swirls talaga. parang hindi ako satisfied, mas marami pang natanggal yung 3 scratch remover. or is it just masyado na malalim mga swirls and hindi kaya ng swirlx kaya kelangan scratch remover na? sundan ko na lang ng swirlx para sa light swirls?
subukan ko this week sa ibang kotse na hindi sobrang tadtad ng swirls.
well as you've mentioned the swirls might be too deep already for swirlX
and you might not be working swirlX to its fullest potential, swirlX really needs moderate pressure to tackle light to moderate swirls and also has to be worked quite long
if you're planning on taking the easy route them use 3m scratch remover first and follow with swirlX to restore clarity but the proper mindset of the detailer should be to conserve the most clear coat that we could so i would say try swirlX with a different approach first
3m scratch remover is really really aggressive its even stronger than most rubbing compounds professionals use
