Page 505 of 591 FirstFirst ... 405455495501502503504505506507508509515555 ... LastLast
Results 5,041 to 5,050 of 5910
    Mar 2005
    #5041
    Quote Originally Posted by madkatz View Post
    oh i see, can you try to compare it with your jazz? im in the notion that souveran doesn't vary that much from 915, the only noticeable difference would be that souveran has more reflectivity and 915 has more depth and this is barely noticeable and only on dark cars.
    Will try sa jazz ko this weekend. Sa ngayon 915 lang nakalagay sa Jazz
    #5042
    Quote Originally Posted by jmpet626 View Post
    Sir san kayo banda sa project 8? Kita ko kasi sa sig nyo
    tatanong ko nga rin sana syo the same question...naunahan mo lang ako. hehehe. Sa Assistant ako near Engineering GSIS Vill.
    Mar 2005
    #5043
    Sa may General ave lang ako sa may tandang sora side banda
    Jun 2010
    #5044
    What's the best prep solvent ? Also Megs Body solvent has been mentioned a lot of times. I wonder where can they be bought. TIA.
    Aug 2008
    #5045
    nabiktima ako ni zorro.. long scratch sya. parang ginayad yung susi or pako. buti nalang di kalaliman yung mahaba. natanggal ko sya using swirlx. yung start ng scratch yung malalim pero hindi sya dent. kakasya swak talaga yung fingernail ko. is there any way para matanggal/ matakpan ito? like yung "magic pen" ba yun yung napapanood sa shopping network matatanggal scratch?
    this was done after wash/asphalt removal/clay/s&g/476 panaman..haayz.
    TY.
    Jun 2010
    #5046
    Quote Originally Posted by ratchet23 View Post
    TY.
    Sir try this article.
    http://www.popularmechanics.com/cars...enance/4216365
    and this video
    [ame="http://www.youtube.com/watch?v=G0UPdEBvCsQ"]http://www.youtube.com/watch?v=RHm6IIQyWBA[/ame]
    Jun 2010
    #5047
    Sorry that was a wrong video. Try this instead
    [ame]http://www.youtube.com/watch?v=RHm6IIQyWBA[/ame]
    Jun 2010
    #5048
    [ame="http://www.youtube.com/watch?v=RHm6IIQyWBA"]YouTube- Repair of scratches in bumper: Applied Colors.[/ame]
    Aug 2009
    #5049
    Quote Originally Posted by silverrain View Post
    Megs body solvent has worked well for me it really removes old waxes and its great for layering on a new set of sealants, it is available in the Megs distributor in kamias.
    Aug 2009
    #5050
    TY.
    you could try having a body shop mix a batch of your cars paint for you, of course it won't really match that well but at least if you use it for touch ups it would be barely noticeable, try to use a very very fine brush and put some on the scratched area, let it dry, if you're familiar with spot wet sanding then you can do this and then just finish with SwirlX to a high gloss.
