*mf051404: Wow that stuff is kinda old school! yes its pretty much the same except that vaporwax is a lot more like a cleaner that really brings out the color of the paint, Nano Sliq is a QD that is basically gloss enhancing agents applied to the paint, basically vaporwax is like a cleaner spray wax. For both you need to use a MF cloth, for the vaporwax i haven't really used it that well to comment too much on it since i basically used it only once and its damn expensive to worth risk buying one top that with pretty bad reviews from most of the detailing forums the world over, but what we did was just use the aerosol spray to mist a little and let it dry for the cure time and remove it via MF cloth, Nano Sliq works pretty much the same without the wait. As for the Nano Glos, Nano Glos for me fills better and looks better, it doesn't always mean that if a wax is harder to remove that its more durable especially if its from TW, the only wax from TW i use are TW Platinum Paste and TW Black Box.
Easy to apply but durable for me would be, Liquid Glass Legend, Chemical Guys M-seal, or Chemical Guys Jet-seal, Jeff Werkstat Acrylic protector. Some products that can be also equally good but requires proper technique would be KSG and Collinite 476
