Results 4,851 to 4,860 of 5910
June 18th, 2010 07:02 PM #4851
Hindi overkill yan ginawa ko sa tucson 915 muna tapos after a week and 1 wash 476s naman. Kitang kita pa din yung shine ng 915.
Bang for the buck talaga yang 915 sa price na 1.2k sa Jazz ko 1 week ng nag uulan tapos nagpa carwash lang ako kagabi ang kintab pa din niya parang kakalagay lang ng 915.
Yung sa ONR nung ginamitan ko ng tap water from blue naging clear na lang siya pero mukang effective pa naman. Yung ONR ko na ginamitan ng distilled water blue pa din siya bakit kaya ganun?
*Madkatz
Na try niyo na ba gumamit ng Diamondite Glass Resurfacing Creme at Glass polishing pads? Sinubukan ko gamitin medyo mahirap kasii nag wowobble yung portercable sa windshiled ng jazz, pinanood ko sa videos ng autogeek kung pano yun gamitin tama naman yung paraan ko.Last edited by jmpet626; June 18th, 2010 at 07:06 PM.
June 18th, 2010 07:08 PM #4852
i have problems with watemarks all over the body.
similiar to this pero hindi ganyan ka grabe.(pahiram po ng pic mam madkatz)
tried using claybar+cleaner wax+swirlx nabawas pero andami padin. pero combination na yan natanggal ko. watermarks sa vios.
what products should I use? I've read from meguiar's forums that scratchx2.0 would remove these. di ba same scratchx and swirl x?
wala kasing detailing shop dito sa province namen AFAIK.
thanks!!
Tsikot Member Rank 3
- Mar 2004
- 2,053
June 18th, 2010 07:48 PM #4853If the Claybar + cleaner wax + swirlx combo was not able to get rid of the watermark, it can be due to one or both of the following:
- The watermark is etched on your paint. Check the watermark closely... try to feel it with your fingertips. If it ain't raised above the paint, it's already etched into the paint. This is usually caused by acid rain that was allowed to dry under the sun. If the watermark is etched, then yes, you'll need something more aggressive than SwirlX. ScratchX may do the job, if you're working by hand.
- Sobrang nag-tutong na yung watermark. Calcified water. Nasty. But not as bad as etched watermarks. Try a water+white vinegar solution (sorry... I don't remember the dilution ratio...). If it works, make sure to wash and re-wax the treated surface.
June 18th, 2010 08:16 PM #4854
natest yung 476 nung sinundo ako from manila... inulan ba naman. hehe
galit nga talaga sa tubig ang collinite... eto yung beading after ma shampoo!
one layer nga lang pala yan ng 476 mga sir
medyo dull nga ang 476 on its own...
kaya eto. after ng mother's FX spray wax, then nanosliq.
kintab ulit! bukas dapat makuhanan ko na to in sunlight
two thumbs up talaga to collinite waxes. thanks for suggesting it, fellow tsikoteers!Last edited by scharnhorst; June 18th, 2010 at 08:18 PM.
June 18th, 2010 08:16 PM #4855
By machine mo ba ginamit ang swirl x? Ang scratch X 2.0 ay mas aggressive kesa sa swirl X. Depende din yan sa pad na gagamitin. Kung by hand mas maganda siguro na Ultimate Compound na ang gamitin diyan
Abrasive charts
http://craigdt.web.officelive.com/abrasives.aspx
June 18th, 2010 10:06 PM #4856
ok by hand lang po. ok will try ultimate compound. tnx! pwede i apply yun buong car?
June 18th, 2010 10:41 PM #4857
June 18th, 2010 10:56 PM #4858
Hindi nakaka tanggal ng watermarks ang by hand. Mahihirapan ka sir. Pagawa mo nalang po sa professional..
Sabi ng BigBerts sa akin kailangan daw machine ang gamit sa Klasse AIO
June 19th, 2010 12:39 AM #4859
eto sureball....mala kobe ang dating.....gamitan mo ng DIAMOND CUT yan using the yelow pad...(syempre makina na gagamitin)....tapusin mo ng FLEET ayus ang butobuto.....
just got home....kapagod...tom na maglinis...mga 5am....hehehehehe!!......lagyan ko 2nd layer 476....pag tinamaad hugas sabay OGE
June 19th, 2010 12:41 AM #4860
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
Ceramic Coating vs PPF (Paint Protection Film)
