Results 4,541 to 4,550 of 5910
- Apr 2010
- 85
June 10th, 2010 05:23 PM #4541thanks, big help talaga ang step 3 at nanosliq...
natapos ko na i-clay yung auto, natanggal naman mostly yung mga watermarks pero may natira pa din, so i guess water etching na yun, would ScratchX remove it? hingi naman ako ng suggestion... hehe... one more, ano mare-recommend mo pangtanggal ng watermarks sa windshield? thanks a lot...
June 10th, 2010 07:40 PM #4543
[SIZE="4"]HI!! pwede po bang sumama sa Monday? I'll be comming from marikina.....saan po meeting place? thanks!!!!!![/SIZE]
June 10th, 2010 09:51 PM #4545
UPDATE ko lang ang list.
Detailers: Heads up!
What: Detailing Seminar ni Sir Edwin
When: June 14, 2010
Where: His place in Caloocan. Please refer to the link below
http://maps.google.com/maps?f=d&sour...1&ie=UTF8&z=18
Head count tayo kung sino ang game sa June 14.
1. Chikselog
2. Dotnetmatt - Dimasalang near Chinese Gen
3. ej (tentative din, wala akong gamit for the eb and shy ako )
4. golti - Las Pinas
5. beeco - Las Pinas
6.
Please update this list and list your name above if you're joining. Sir Edwin is asking for updates on how many will join. Thanks!
As for the meeting place, wala pa po nababanggit si Sir Edwin if magme-meet pa or direcho na to his place.
- Jan 2009
- 56
June 10th, 2010 10:57 PM #4546UPDATE ko lang ang list.
When: June 14, 2010
1. Chikselog
6. jozep - QC (not yet 100% sure)
- Jan 2009
- 56
June 10th, 2010 11:05 PM #4547double post
- Aug 2009
- 1,553
June 11th, 2010 02:09 AM #4548I agree with JM on this, 915 would make your paint look darker and Klasse Twins would add more mirror like shine, if you want shine then i would suggest you put on a layer of 476 just for protection and then applying any nice shiny wax coating on top, afforadable alternatives would be TW Platinum, Nano Glos, for red i would also recommend Reflections
- Aug 2009
- 1,553
June 11th, 2010 02:11 AM #4549Most probably you already removed the embedded minerals deposited by the water marks so yeah the next logical step would be to use ScratchX, i would recommend SwirlX if its not bad though because ScratchX is quite aggressive, its true that you would easily remove the marks and swirls with ScratchX but you also remove more clear coat in the process
- Aug 2009
- 1,553
June 11th, 2010 02:14 AM #4550
^ Ako I just use the good ole mini elm327 OBD2 scanner. Pero usually sa long drives ko Lang...
