Results 3,891 to 3,900 of 5910
- Dec 2009
- 14
May 9th, 2010 09:27 PM #3891thanks for the inputs madkatz and chicselog....
i may have been paranoid that i might take off more clearcoat than necessary when i was applying the swirlX... will try to adjust the pressure and duration of application and/or the amount of product next time.... as for my applicator pad, i used the microtex wax applicator pad, should i switch to a foam applicator?
will also try to take pictures before and after
just for clarification... you don't need to wait for SwirlX to dry, correct? you have to wipe it off right after working it?
May 9th, 2010 09:51 PM #3893
Yup it does say so in the label. One thing that you'll notice after using NanoGLOS on your paint is that in about 5-15 minutes, some (in my case) parts of the paint developed what Microtex calls "coating moisture", it's like, well a moisture but not really that moisture na basa. It's no issue, just wipe it off
NanoGLOS and SLIQ IMO were designed to work together talaga. I do hope that it will be also as durable as other waxes out there. Since isa sa mga habol ko sa wax is durability. I'm more after paint maintenance than show car shine because well, you know how harsh our weather is, especially during rainy season.Last edited by Chikselog; May 9th, 2010 at 09:58 PM.
May 9th, 2010 10:14 PM #3894
May 9th, 2010 10:17 PM #3895
May 9th, 2010 10:26 PM #3896
May 9th, 2010 10:31 PM #3898
May 10th, 2010 12:49 PM #3899
have your compression checked... if Manual yang Montero mo... try mo patulak if ayaw mag start...
