guys help me!! nalagyang ng stain ng mghty bond un body ng kotse ko., di ko alam kung anu solution ang ilalagay ko para matangal., itry un solution na remover ng mighty bond pero ndi parin natangal., even gas., ayaw pa din!!![]()
natuyo na?
di na rin ata kaya yan ng super glue remover, baka tamaan pati paint. kung maliit lang, just leave it as it is. pero kung malaki, baka kailangang i-paint over... dunno ha?
di na kaya ng super glue remover? did you let it soak? kasi yung sa car ko tagal na meron drop ng super glue nakaya pa din tanggalin ng remover e, cotton bud lang with rempver gamit ko.
Yun mighty bond kasi tinutunaw nya kung ano man yun malagyan mo. You may have to sand it off and kung natunaw nga yun paint kailangan mo pa touch up, then wet sand ulit para pumantay yun kulay.
Minsan nahahabol pa sa light sanding.
mighty talaga yan! even sa skin sandpaper ginamit ko.
nadikitan din kasi ako ehtama si boss otep, very light
sanding with h20 then habulun mo sa wax.
If all things fail, try:
1. High-set hair dryer to crumble the mightly bond.
2. when it crumbles, it'll come off.
Not sure. naisip ko lang. hehehe
may remover yan..
if i remember correctly, somebody asked about that some time back.. same problem.
try to get the glue remover first. kung ayaw, you might resort to a more abrasive solution. last resort na 'to though: wet sanding.
ganong kadaming mighty bond ang napalagay sa paint mo??? mahihirapan ka na tanggalin yan... basically sunog na yung clear mo dahil sa mighty bond, hndi mo na mahahabol yon... kung sa tingin mo eh safe pa yung paint, try mo i-sand yung mighty bond (carefully), kapag sinuwerte ka at hndi masyadong damaged yung clear coat (very little chance), wet-sand mo yung surface kasama yung clear around the damaged area using 1500 or higher grit wet sand paper, then spray one coat of clear, wet sand ulit, tapos spray ka ulit ng clear, tapos isa pang wet sand, then final coat of clear... it depends kung anong rate ng wet sand paper ang dapat mong gamitin at kung ilang coat ng clear ang kelangan mo para mairestore mo yung clear, so kung hndi mo ma-judge, just bring it to a body shop. It's not easy lalo na kapag wala ka pa experience, kahit pag-spray ng clear coat hndi ganong kadali... GL!
mukang di na makakaya., a lost chances na., matuyo na kc.,sabi sa detailing shop., re paint nalang solution dun., guys thank you sa mga suggestion.,
