Page 5 of 10 FirstFirst 123456789 ... LastLast
Results 81 to 100 of 248
    oki doki so megs then 915
    gusto ko kasi isang bilihan nalang
    pero ubusin ko muna nanofil and sil at existing carnauba hehehe
    Jun 2004
    Pag naubos ko tong Nanoglos ko try ko ang Klasse twins or Collinite.
    Share ng pic bago matulog. Hinaplos ko muna para pag gising malinis. Hahaha. Grainy. Phone cam.
    No flash.
    Feb 2011
    Quote Originally Posted by venerzky View Post
    No flash.
    Ganyan din gamit ko sir. I had my car waxed using collinite last month, then every week, i wax my car with nanogloss.
    No flash.
    Jun 2011
    im using mothers synthetic wax..
    last for up to 12 washes...
    unlike other wax isang car wash lang...
    hindi din basta basa kinakapitan ng dust and dirt...
    Aug 2012
    *ninjababez: Polish always comes before sealant/wax. You actually can see it on the bottle description. Meg's Ultimate Polish - Pre-waxing Glaze. It is a very fine polish based on Meg's #205 (Mirror Glaze Ultra Finishing Polish) but contains much more polishing oil (glaze) and less micro abrasive.
    Aug 2012
    Add ko na lang, if you don't know which product comes before or after, just check what kind of product it is and refer to this diagram. e.g. if it is a Polish, then it comes before Paint Sealant/Wax.
    im using collinite 845 and it only lasted 4 washes/1 month. does using a car shampoo helps in maintaining the wax? im using one though.
    Jun 2004
    Quote Originally Posted by raymm View Post
    So sa isang buwan 4x ka mag-carwash?
    Jun 2011
    try nyo sir... mothers california gold synthetic wax... 12 washes po talaga... or one month
    after waxing you can feel parang meron syang addl. na top coat..
    pati alikabok hindi basta basta kumakapit..
    *cathy... i do wax every 1.5-2months lang... partida yan bugbog sa byahe at alikabok sasakyan ko...
    pero i recommend once a month pag mothers gamit mo...
    Nov 2014
    Mga sir,, meron po bang nakakaalam sa inyo opti coat? Maganda po ba yun?
    Aug 2012
    Quote Originally Posted by paos View Post
    If sawa ka na mag-wax, then Optimum Opti-coat 2.0 is a very good choice. It is a kind of paint coating. You wash, clay and polish the car first, then apply Opti-coat 2.0. Any imperfection should be fixed first before application.
    Paint Coating
    - Will not wash or wear off. Can last for 2 years or much longer.
    - Provides a clear, hard coating that provides increased protection against the elements.
    - Paint finish has to be properly prepared before application. Any blemish or contamination on the paint will be permanently locked in.
    - Cannot be easily reapplied when slickness and protection begins to fade.
    - The professional choice for permanent paint protection. No more waxing!
    Recommendations:
    - Optimum Opti-Coat 2.0 (Lasts for the car's lifetime)
    - GTechniq EXO Ultra Durable Hybrid Coating (Lasts up to 5 years)
    - CarPro CQuartz and CQUK (Lasts up to 2 years)
    Note: Coatings are scratch-resistant but they are not scratch-proof. Clear coat is far thicker than coatings.
    Clear coat thickness = 38 to 63.5 microns (1.5-2.5 mils)
    Coating thickness = 0.5 to 2 microns
    Nov 2014
    Sir advisable po ba opti coat sa bagong sasakyan? May idea po ba kayo sir kung magkano?
    Nov 2014
    ^ Isn't Opticoat 2.0 the consumer/DIY version? It's thinner and has a shorter lifespan than Opticoat Pro, which can only be applied by Opticoat PH. I inquired kasi, messaged their Facebook account about it
    Quote Originally Posted by kai s. View Post
    may nakita ako sa olx permanent daw * 5k for diy
    Feb 2011
    Ayone tried autogylm? Medyo expensive nga lang sya.
    Aug 2012
    Quote Originally Posted by sientobente View Post
    Ang na-try ko pa lang from Autoglym is their Glass Polish. Easy to use and smells good. It's a UK brand established in 1965. Price is similar to Meg's. You can try either Extra Gloss Protection Sealant or High Definition Wax.
    Feb 2011
    Quote Originally Posted by red_one View Post
    Thanks for the feedback sir. Where do you get it cheap? I usually see their wax prices going from 3.5k to 4.5k.
    Aug 2012
    Yes, Opti-coat 2.0 is for the consumer/DIY community. Opti-coat Pro is only available for professionals so you won't be able to buy it for personal use.
    Opti-coat Pro is more concentrated and will be thicker but max thickness is still 2 microns. Expect Opti-coat 2.0 to be 1 to 2 microns. Regarding durability, both products will "become" the top coat and not "wear" away like sealant/wax that weaken or diminish with exposure and maintenance.
    If you worry about thickness (though you should not be), then apply Opti-coat 2.0 twice.
    Aug 2012
    You can use Opti-coat 2.0 on brand new car if you want to. It is a matter of preference. It is a permanent coating so you wouldn't need to apply sealant/wax on the car anymore. Puro car wash na lang ang gagawin mo. Price in OLX is ~P5,000.
    bagay yata sa binay collection mo bro
Car Wax Brand
