Originally Posted by
theveed
Note also that this only works if your paint is well protected by wax or sealant. This WILL NOT WORK on the typical dirty paint surface (unpolished, uncleaned, unwaxed).
After the final rinse...
1) Grab the hose and remove the attachment (if any) from the hose, let the water flow naturally from the hose tip. If not using a hose, use a "tabo" and gently let the water flow out from top to bottom. This is what I call "drying with water". If you do your final rinse with a spray-type water pattern, you'll get a lot of water beads which stays on your paint. A heavy flow of water is much more effective on "dragging" surface water away from the paint. Leaving you with minimal water left to dry with a towel or chamois.
