Results 1 to 10 of 64
November 5th, 2007 10:31 AM #1
bought this at true value ATC for P200+....haven't tried it yet, still don't know if it's at par with my CWB....pero it's made with the same silicone grade rubber or something....I just notice na parang mas madaling hawakan compare sa CWB...
November 5th, 2007 11:44 AM #2
Sige sir balitaan nyo kami sa performance nyan.
Sana sa TV shang meron din.
November 5th, 2007 12:21 PM #3
Looks like the real thing, hope it does well, saan naman kaya gawa ito?
November 5th, 2007 12:30 PM #4
^^^^Taiwan...hehehehe
but I comapred it side by side with the jelly belly sa true value the rubber looks and feel the same...and when I got home compared it with my CWB...parang mas malambot pa nga rubber niya comapare sa CWB
- Oct 2007
- 12
November 5th, 2007 10:52 PM #5i also have 1 and tried it last sat. ok nman sya, never had any scratch which is most important. it says in the packaging that it clears 90% of the water pero feeling ko around 60-70% lang.
November 6th, 2007 11:26 AM #6
tried this last night and ok naman, the rubber is softer compared sa CWB ko...so it bends more easily...
November 6th, 2007 03:20 PM #7
Maybe it's just me but I prefer the old microfiber/cotton terry towel method. That way I can also feel for anything inconsistent on the paint surface, not just dry the car up as quick as I can (which can also be done with a large microfiber/waffle-weave towel).
My friend loves the chamois, he says it dries it up in one swipe.
Another friend, on the other hand, uses a leaf blower to blow the water beads out.
Still on topic since you asked about alternatives
November 6th, 2007 07:48 PM #8
I actually still use microfiber towel after using those water blades, 'coz you can only remove so much water when using the blades....
November 9th, 2007 11:29 AM #10
high idle RPM at engine start
