Can U guys recommend any step/ideas on how to properly clean or maintane the engine? I have been using 3m tar remover and meg's APC++ for some dirt and grime on the metal cover but I think it has a slight negative effect on the rubber hoses and plastic covers of the engine, its gettin dull or something like that (i'm not really sure) What are the proper steps on cleaning the engine? what do u need to apply on the rubber hose/cover of an engine to make it look new again?
I would really appreciate any ideas that you can share on this one.
Thanks for the reply blackmagic, what specific dressing is that? Im basically new on detailing stuffs and Im sorry for being too stupid on this one, Will it hurt the engine if I directly spray water on it? Do I still need to use a car shampoo after degreasing?:confused:
i have a little info to share, pag naglilinis ako i apply kerosene to remove the hard grime then sinusundan ko ng soapy water.rinse tapos punas. for the rubbers and plastics i use tire black so that the hoses wont crack. pareho naman silang rubber ng tires so tire black should work well with the hoses. i just dont know if it applies to gasoline engines. mine's a diesel kc. with gasoline engines you have to be careful not to wet the electronics.
baiskee: Yes, as long as you use it as printed sa instructions
Hens: hehe... sa benz mo ingat sa mga connectors na masprayan ng silicon...
Monodon: Tire black in general are harmful for rubber,that's why cheapo tireblacks turn tires to brown.
Bossing: Parehas lang po.
Kimpoy: That's fine... Rinse mo muna with soapy water coz kero and water dont mix so one can not remove the other.
