Page 115 of 120 FirstFirst ... 1565105111112113114115116117118119 ... LastLast
Results 2,281 to 2,300 of 2400
    #2281
    Had my Optiguard's first session in Ortigas branch and I'm impressed with the results. Willy and the staff are very accomodating.
    Anyway, I'm sorry if this was asked before. I can't find the right keywords to search for it. Here's my question:
    What to avoid from removing the sealant?
    Does frequent washing removes it?
    Can I still put wax on it?
    TIA.
    Mar 2005
    #2282
    Make sure yung car shampoo ay formulated para di maka strip ng wax and dapat tama yung amount ng shampoo. Pag masydong matapang may tendency maka strip ng wax.
    Pwede lagyan ng Pure Carnauba wax, yung walang cleaners. Like Mothers Step 3, Reflections Top Coat and Collinite 845/476s
    Aug 2009
    #2283
    *Sniper Wolf: totally agree with jm. but just my two cents on the matter, not related to BB so you might still want to get their advice
    1. you have to avoid removing them chemically and mechanically, using strong shampoos and detergents will strip sealants, some sealants are detergent proof as they claim but still reduce when washed with strong detergents. Mechanically when you use chamois to dry wipe your car using strong pressure, so try to use a MF drying towel
    2. frequent washing can inevitable reduce your sealant, but the question would be how many washes? if you wash your car properly and safely your sealant could last you up to 1 year especially if its well maintained and boosted with other protection, conversely poor washing methods can lead to faster deterioration of the sealant.
    3. Yes, it is actually advisable to wax your car once you car has been sealed, pls do allow 24 of cure time before waxing your car, waxing the car offers another barrier of protection against the elements making your sealant last longer since it does not suffer the abuse taken in by the wax. Wax would be the first line of defense your car has against pollutants and contaminants and when you have a sealant you have another tougher and more durable layer once the wax fails.
    Hope this helps.
    #2284
    *madkatz and jmpet626,
    Thank you. Very informative indeed
    'Was wondrin' if vinegar treatment on water-spots should weaken the sealant as well?
    Lastly, sounds like a dummy question but I'll try: Is there a "mild-carwash" option in BigBerts to preserve the Optiguard?
    Thanks again.
    Aug 2009
    #2285
    *Sniper Wolf: most probably it would affect the sealant since its an acid. As for the shampoo question, well they said their shampoo will not strip wax, but for me i usually do it myself and only have it washed monthly or something since the vehicles here are washed weekly, what i did with megs is bring a bottle of NXT shampoo and avail of the carwash service, pay the full price but tell them to use NXT instead.
    #2286
    what is the difference between a spray wax and the regular one? i can't decide if i should get the spray kind nxt or just the regular one.
    Aug 2009
    #2287
    *daney_waney: you should get the regular one first and then the spray wax after, the spray wax is a wax thats less concentrated, it does not offer any long term protection and its just used as a booster over you regular wax to prolong the waxes life span, which in some cases is needed for the protection to last 1 month
    #2288
    Thanks madkatz. Will try out meguiar's nxt.
    Sep 2008
    #2289
    sir nagdedetail po ba kayo ng headlight papaalis ko lang po sana mga fine scratches nya? at how much po?TIA
    #2290
    Rain Harry Tire black gamit ko magaling naman...
    You can't get any more tire- and environmentally- friendly than Rain Harry Tire black's base...
    Tip for the splatter, konti lang lagay, tama lang para ma-wet-look tires.
    Sep 2009
    #2291
    sirs, good day po. .
    plano ko pong mag pa optiguard sa innnova 2010 namin. meron na po syang
    mga swirl marks, nagkamali po kasi kong gumamit ng carcover, ayun swirl
    marks. matanggal pa po kaya sa optiguard (PPP) yun? Or meron pa pong ibang
    dapat gawain bago yung optiguard?
    TIA. .
    Jan 2003
    #2292
    Quote Originally Posted by dadmonpogi View Post
    TIA. .
    yes we will polish the car first before applying sealant.
    you can go 2 ways.
    1. enroll the car under optigurad >>> http://bigberts.com/optiguard.htm
    2. stage 1 paint detail
    as for the car cover. you can lay down clean towels on the roof and hood before you put on the car cover, to minimize swirls
    and make sure before you cover the car it is also clean.
    Sep 2009
    #2293
    thanks impulzz, magpa sked na ko siguro ng PPP after holy week, bka po sa
    ortigas, lapit sa opis ni misis. Gaano po katagal ginagawa yun?
    #2294
    Hi sir. Puwede po bang Collinite 845 ang gamitin pag nagpa wash wax or double wax sa inyo?
    Apr 2006
    #2295
    Question
    what is the difference between the New car Paint Protection Product and Optiguard ? prior to the big price difference? is it using the same wax? same process?
    I just had my pickup done by BB-ortigas, i availed the New Car Paint Protection as my pickup is just 2 months old.
    thanks
    Jan 2009
    #2296
    How much is your 500ml Carlack68 Long Life Sealant and Red Carpet Tire Cream?
    Jan 2003
    #2297
    Quote Originally Posted by daney_waney View Post
    pwede po sir, just tell our manager that you want colinite may konting additional lang
    Quote Originally Posted by t3kk3n View Post
    Question
    new car paint protection is a one time process for new car upto 2 months old
    Optiguard is paint protection program that includes
    [SIZE=2][SIZE=2]Three (3) Quarterly acrylic paint protective sealant maintenance sessions, [/SIZE][/SIZE][SIZE=2]
    One (1) paint detailing session for light to moderate surface defect removal.
    and uses [/SIZE]
    [SIZE=2][SIZE=2]German acrylic paint protective sealant[/SIZE][/SIZE]
    Jan 2003
    #2298
    Question
    and uses [/SIZE]
    Jan 2009
    #2299
    Jan 2003
    #2300
    Quote Originally Posted by jozep View Post
    carlack lls is 1400 and tire cream is 150/tub
Big Bert's Thread [ARCHIVED]
