Results 1 to 10 of 12
- Mar 2005
- 211
March 14th, 2005 10:07 AM #1Mag pips anong downfall ng hilamos lang? alin ang masmaganda strip to the metal lang o patungan na lang yung old paint?
March 14th, 2005 10:22 AM #2
hilamos lang kahit change color because OEM primer is still the best. strip to metal ka lang kung may rust formation na IMO.
March 14th, 2005 10:25 AM #3
Like what ssalon said, hilamos lang kung either change color lang or re-paint using the same color. OEM primer pa rin a the best. Kung matindi na kalawang a kalat na, then strip to metal. If you do that, try to get a hold of the OEM primer.
March 14th, 2005 10:26 AM #4
no need to strip to metal if its just a washover, even for a color change, unless you have some rust on your cars body. Striping to metal is not only more expensive, it exposes your cars body to potential rusts if not preped well.
March 14th, 2005 11:08 AM #5
agree with all posts above... strip to the metal if there's rust and other major defects to consider. OEM primer is very hard to beat so make sure to get the same quality.
as for hilamos, pwede nga ito sa change colors, basta general "hugas" ng car mo. if ever, go for two-stage paint... ung may top coat afterwards.
its always good to have your car assessed muna by a professional if you're not sure about it.
hope this helps.
March 14th, 2005 11:21 AM #6
hilamos lang. sayang yung oem primer. if you do strip to metal, make sure you have it done by a reputable shop. and make sure na oem primer ang gamitin.
March 14th, 2005 03:59 PM #7
Sayang yung electric anti-rust dipping sa factory kung strip to metal mo din lang.
- 10,620
March 14th, 2005 04:06 PM #8nasabi na nila...
OEM primer is the best
so kung kaya i strip to primer mas oki.
- Dec 2003
- 22
March 16th, 2005 01:09 PM #9how do you do the "strip to primer"?
ito ba yong tinatawag na rub down?
di ba gamit g mga shops ay chemical paint strippers? tagos hanggan primer pa rin 'to
March 16th, 2005 01:17 PM #10
basta magaling pintor kahit hilamos or strip to metal maganda kakalabasan ng pintura.
I don't feel any diffeence ng DCT Sent from my iPhone using Tapatalk
(2023) Ford Territory
