Results 1 to 15 of 15
    Feb 2017
    yung water pump para lumakas ung tubig pwede ba gamitin un gagawing portalble pressure washer?
    Quote Originally Posted by danegoesonline View Post
    Pwede kung sa pwede kaso tuloy tuloy ka dahil pag stop kailangan mo alisin sa saksakan
    Bili ka na lang nun mga portable pressure washer mura-mura lang.
    Jan 2009
    Yes and no.
    Yes, if it has a pressure tank, then water from it will be pressurized... somewhat. If 40 PSI (typical pressure of residential booster pumps) is good enough for you.
    No, because, it's not purpose-built for pressure washing. For one, it still needs a nozzle to go with it, to which the pressure is likely not enough, and these pumps will come out more expensive.
    On the other hand, a proper pressure washer already includes everything you need. Suffice to say, it's built for the sole purpose of pressure washing. It can produce about 1,000 PSI of pressure, more portable, and cheaper.
    It is very unsafe as the pressure is unregulated. The hose and attachments could explode in your face/ cause injury.
    That is the reason why pressure pumps have regulators that automatically cut-off upon reaching the required pressure.
    puede kung puede.
    i suppose that's because you already have the the pump.
    do you have the other parts, like the tubings?
    then you'll have to assemble it pa.
    hassle, unless you enjoy DIY.
    just perusing olx, there are several for-sale ones, ready-to-use.
    our house is supplied by a pressure tank. it is easy for us to connect the garden hose, and do some pressure-washing if we want to. the pressure is not strong (40-60 psi), "but it suffices".
    Jun 2005
    Pupwede naman. Ganun gamit ko. Yung hose ko is connected to a faucet sa pressure tank. So i get pressurized water sa hose.
    Sent from my MI MAX 2 using Tapatalk
    pwede provided kaya ng nozzle mo given pressure ng water pump mo. baka kaya nga ng hose but maghiwa-hiwalay nozzle mo talsikan ka pa.
    Pwede, ganyan lang gamit ko before.
    1. The pressure tank needs to be by-passed. Ibig sabihin yung papunta sa pressure tank dapat may valve na sarado tapos yung water papunta sa hose e meron ka tee before the valve.
    2. Pwede yan continuous, mababa lang pressure nyan. I used a 1/2 hp pump before the pressure was only maximum 150 psi.
    3. Kaya ng garden hose at garden nozzle ang 150 psi. Ang problema lang yung hose connections mo. Paminsan-minsan itatapon nya yung nozzle pag di mahigpit yung hose.clamp. So yun lang talaga ang problem nyan pag maluwag ang clamps.
    PERO, since ang price ng 1/3 hp pump ay P3500, add mo pa price ng good quality garden hose and nozzle plus very good quality hose clamps, E MAS MURA PA BUMILI KA NA LANG NG PRESSURE WASHER P4k lang.
    ^ And the inconvenience of wiring and earthing the motor, dipa portable. lol
    I saw some seller sa shopee... around php5,000
    Bosch
    Self priming
    110 bar
    1300 W
    This is good since pwede na hindi direct sa water faucet ang source, sa water bucket or tank pwede na...
    Anybody tried ? Or ano alternative nyo? Plan to buy on December...
    Bosch
    Self priming
    110 bar
    1300 W
    carousell.
    ads there show brand-new pressure washers costing about the same or even less.
    i believe they can also higop from buckets?
    carousell.
    Yes, doc. Which is good for quick garage wash plus you can have foam gun...
    2k+ lang mga China made na pressure washer. Kawasaki binili ko
    Hi bruh, i saw kawasaki brand as well... how many bars rated ? hows the pressure using bucket?
    Hinde ko alam pero malakas naman.
Can I use water pump as pressure washer?
