Ask ko lang pag washover ba kasama yung ilalim ng hood yung mga loob ng pinto sa compartment yung loob di ba same sila ng body color. i mean kapag ng pa washover ba wala ng makikita na dating kulay ng car in any part of it? tnx
ah ganun ba yun? eh how much naman po usually ang cost nung change color?
a usual washover will cost you around 27-28k(small size sedan)
choices of k92,nax urethane,nippon & du pont paints
whole outer panels to be painted.
doors,fenders,hood,trunk,roof,running board and bumpers
service Includes full detailing.
-interior detailing.......................................LG 2 autostation
-exterior detailing......................................meg uiars waxes
-engine detailing.......................................me guiars cleaner chem.
-glass detailing(removal of acid rain marks)....meguiars cleaner chem.
-complete wash,under,engine,vacuum.
*guaranteed no oversprays,"baklas"
change color will cost you:
43k (small size sedan)
only dashboard will remain in the interior.
bumpers,fenders,windshields and door glass will be removed
*il subject you to replace the old windshield mouldings to newer ones
*all broken and missing clips will be supplied
*aircon lines and freon will be removed to give way in the engine bay
*radiator,condenser,aux fans and such will also be reamoved.
same goes for the paint.
whole exterior,interior,flloring,engine bay,
trunk space will be painted.
your choice of paint.
(paints *same choices above)
after painting,car will undergo full detailing process(*same as above)
09222255122
09155057705
7222903
*patpaint autoshoppe
http://s150.photobucket.com/albums/s...%20autoshoppe/
*the hatch used to be silver![]()
Isn't washover different from change color? Anyways, price aside, pag usapang hilamos at same color pa rin naman, it's standard na kasama ung mga panels ng pinto na painted with the same paint as the exterior. Same with the compartment, etc. kasama yun. That's why pag hilamos e standard na tinatanggal ung mga headlights, accessories, and even siding ng pintuan para lang mapinturahan din ng maayos yang mga yun. Pero may ibang paint shop na tuso at kung ano lang kita un lang din talaga dadalihin, kaya maigi na na iklaro mo sa paint shop na magwawashover kung isasama nila o hindi. Yung iba kasi sumisingil pa ng extra para jan.
its standard talaga na to remove outer parts of the car,
para hindi madumi ang painting process at para hindi maoversprayan.
up to now yung iba ndi gnagawa to,just masking.
pero the paint ends up with sharp edges at madumi tingnan.
paint easily chips off also.
yup,you have to clear things out with the shop muna,a usual washover will cost you around 27-28k(small size sedan)
before going on with the paint process..
it depends also on the condition of the car if matino pa interior paint ng car,
i personally wouldnt agree to paint it,kahit mag add ka pa.
its because its there you'll know if the car really is sariwa pa.
iba talaga ang finish ng hot spray for interiors ng assembly line.
some shops also do naman all out for the whole washover
pero it differs on the price range din.
kaya the main issue on this topic is,
how much are you willing to spend on your car and how you want it to be done.
if a shop charges you 30k it should be 30k till the end.
if it asks for more.iba na yun.
baboy na kausap yun and baka may bisyo yun or mukhang pera yun.
hahaha
prices wouldn't change that quick while your on the process.
its not like freelancer in banawe commonly called for holdups.
when your already having the service,prices will mysteriously goes up
and abuses the chance na you are caught in the middle.
if it happens to you.kwento nyo naman,
so that other people wouldn't go through the same fate.
kung same color wag mu na pasama kasi treated ang original paint at kailangan yan pag binenta mu para masabi original kasi pag tampred na baka paghinalaan na total wreck and do not agree with scrape off unless sa casa kasi mawawala ang base coat na anti rust at electronically ionized paint
