Results 1 to 10 of 10
    Is it true that bird poop can stain your car? If yes, how do I get rid of the stain? I have stains in my black car and my husband said they were from bird poop, I thought it was something else.
    Jan 2004
    not stain but damage the paint of your car. bird poop is acidic and can eat away the layers of paint on your car in a matter of hours. learned that the hard way.
    Mar 2004
    Yup... bird poop does eat through the paint, lalo na kapag naiwanan sa init. Best way is to wipe off a fresh drop as soon as possible! This also holds true with tree sap (plant fluids). Same as bender... I learned it the hard way.
    Yup correct sina bender at RDL. It would help if you have some protection ie wax or sealant on your paint. My brother's car suffered the same fate. The paint is scarred due to bird poop while i've had my car bird bombed for days with no visible defect. But its really a case to case basis. Depende rin minsan sa kung ano ang kinain ng ibon. Best is to rinse it off the moment na may makita kang bird poop.
    hirap kasi na everytime tumae ibon kailangan hugasan agad...
    any way to protect the paint?
    will ziebart diamond gloss protect paint?
    ako din kasi yun gproblem ko badtrip puro butas tuloy pintura ko..
    ano kaya pwede gamitin to protect the paint?
    Originally posted by bender
    not stain but damage the paint of your car. bird poop is acidic and can eat away the layers of paint on your car.
    Ate Tess same thing happened to my black car, stain is gone but the mark of the "poop" is still there. :freak: :mad:
    Jul 2003
    ako i was travelling in taft when suddenly itong mga wet paint ng lrt tumulo sa hood ko, had it waxed pero may stain, ginawa ng mequires binuff, ayun tanggal, kaso hindi pantay na color since hindi binuff buong car, so i guess i need 2 step detailing next time around
    Mar 2012
    up ko lang.. detailing na lang ba talaga solusyon para mawala ung mantsa ng bird poop and tree saps?
    Apr 2012
    Quote Originally Posted by stickers View Post
    * sir stickers, isang solusyon lang ang detailing para mawala ang mantsa ng ipot ng ibon. kapag di malalim ang mantsa sa pintura ay pwede pa mahabol yan ng simpleng detailing lang like wash-clay-polish-wax. if nag-etched na ang marka ng bird poop at di na kaya ng mga cleaner at pang-polish, next ay yung mga medyo abrasive na like compounds ang pwede gamitin. if di pa rin mahabol ng compound (w/c i doubt) ay pwede na yung mas abrasive pa, wet sanding using sandpaper grit, pero magsuffer na clear coat mo niyan at ninipis na rin pintura mo sa part ng niliha mo.
    for best protection, dapat palagi naka-sealant at wax ang mga rides natin para hindi didikit agad ang mga contaminants. mapatakan man ng ipot ng ibon o tree saps ay madaling tanggalin. kung sakali naman na mapatakan ng ipot ay huwag hayaan na matuyo o magtagal ang ipot ng ibon sa pintura ng sasakyan natin, pwede naman punasan agad kapag nakita na may patak ng ipot. very acidic ang ipot ng ibon at kahit may protection posibleng magmarka pa rin.
    Yup, bird poo can eat through even the best combinations of sealants and waxes so habang "sariwa" pa yung poo, quickly wipe it out kahit tissue lang yan, I'd rather have swirls caused by the tissue paper instead of poo-eaten clearcoat. Kapag naman tuyo na yung poop, grab an MF towel, then basain mo ng husto yung part na may ipot then cover it with the MF towel. It should soften the poop enough to safely wipe it off the paint without causing a scratch. Kapag tree saps naman, if you regularly park under a tree, "kilalanin" mo yung puno kung umiipot din, if it does, then avoid it at all costs. At school where I park, may spot dun under a tree, solo mo yung parking slot na malapad, yun nga lang ang lakas umipot ng puno. Kawawa pintura. Mas mahirap ang tree saps since most of the time buong kotse mo ang damay, ang liliit pa kala mo umaambon lang.
Bird poop stain
