Results 1 to 7 of 7
    Mar 2007
    mga chief, meron ba nabibili product na pwede apply sa loob ng salamin ng oto para hndi mag condense? lamigin kasi ako kaya pag umuulan i rarely turn on the AC just the fan ok na sakin. yun nga lang doing this mag-ccondense ang salamin. any ideas?
    Dec 2003
    err switch the vent controls para ang hangin lumabas dash vents sa harap na malapit sa windshield..?
    May 2007
    turn your A/C vent control to out position do not use recirculation and let the air out. This is happen if you you let air from your car too long. Cleaned your windshield too w/ glass cleaner and used newspaper to wiped not cloth.
    Jul 2006
    Using just the fan will mist the interior. Turning on the AC at least to the windshield vents at minimum coldness should work to remove moisture. The AC is there to pull moisture out of the cabin, that's how it cools the interior. Using the fan plainly will just bring in outside, moist air.
    i think you can try the a-toy glass cleaner. may ganun daw na capability. ok naman daw siya pati mura pa
    Mar 2007
    mukhang mabangis mga produkto nito ni a-toy ah. sige sususbukan ko. salamat sa mga tips mga chiefs.
    Quote Originally Posted by mbeige View Post
    Yun na nga. Kaya maganda pa rin ang naka rain visor. Pag umuulan at malamig naman, u can keep ur fan/AC off ng bukas lang ng kaunti windows. Walang moist yan. Pag medyo mainit sa loob, turn on AC. Just dont turn on fan only na closed ang windows.
    Tried those Atoy products, pero talagang force of nature ang moist air so meron pa rin yan.
anti-condensation
