Results 1 to 20 of 26
    Sep 2006
    mga preps, pano ba to look 4x4 iyong stock na 94 4x2 hi lux?
    Gusto ko kc pataasin ng konti iyong looks nya... tnx
    You can adjust the torsion bars and put shackles at the rear.
    But i think it will not be as high as 4x4 hilux because of the difference in platform.
    Jun 2007
    sir dong,
    sa front pwede un torsion bar lift pero ttigas un ride..pnka mgndang approach dyan is if may budget ka pwede ka mg downey 2wd lift kit..around 3 inches ata..tpos sa rear pwede e spring over..then palit kna ng tires pwede kna gmit ng 32-33 inch tires ...as for power loosing on larger tires..no probs yan kc hliux dami pwede gwin pra ma restore un lost power by having larger diameter tires...
    Sep 2006
    Sir mga magkano budget para dito? sa downey 2wd lift kit..around 3 inches ..tpos sa rear pwede e spring over..
    San pwede Bumili, magpagawa o magpa set up nito....
    Salamat po...
    Sep 2006
    how about iyong sinasabi na palitan iyong hanger sa likod at adjust ng torsion bar sa front? ano performance kung ganito set up? 2.4D lang kc engine na 2L. salamat
    Stiff ride. Its up to you, an inch or two will still be ok. I think.
94 hilux, how to make 4x4 look
