ano maganda gawin sa GSR
thanks
IMO, keep it stock. lahat pati yung factory installed speakers. Its easier to sell pag ayaw mo na. wala e,, dehins ako flashy pag cars. horner lang ang kinalikot ko ng todo
make it look like a sleeper...
Inside: Install Recaro Seats and Evo 4 Steering Wheel.
Make your rear bumper look like this...
Then exterior is closer to this one but a lot lower ground clearance...
or check this links out:
http://eugene.craigslist.org/pts/321237009.html
http://www.cardomain.com/ride/283753
or if you have more money, why not make it 4WD like real Evo's?
If that was mine and it was just for a little show and a little go, lowering and some 16 or 17 would look nice. Then maybe a good sound setup, HU, front seps, 4-way amp, sub.
Eventually engine swap, a MIVEC or a 4G63T. Maybe a tower bar for aesthetics mostly. I will get rid of the stock spoiler. If it's the 97-99 tail lights, I will change it to the 00-01 lights.
Change steering wheel, shift knob and pedals.
You can swap a 4g92 MIVEC engine for more power, the 4g63T would have to come from a Lancer Evo because the 4g63T on the Eclipse will not work for the GSR. Also be prepared to loose the A/C on the car, somebody here did the swap to the 4g63T and they couldn't make it fit with the A/C even after swapping the front bumper and hood with the Lancer 4dr to get more engine space. You could also just turbo charge your stock engine for mild boost to get the added power.
As far as the suggestion of making it look like a sleeper it's a great idea, except none of the picture shown would appear like they are sleepers.
The stock GSR engine isn't known for being able to hold boost (correct me if I'm wrong).
I'd prefer a 4G63T swap or, if you're really adventurous, an FTO 6A12 V6 swap. That's 200 naturally aspirated horses, and it's not that difficult... well, except for the wiring, but then there are technicians here who know how to do this, already. And there are no aircon fitment issues.
The sound of a V6 Lancer is wonderful... and seeing and hearing one on the dyno made our SR20s, FSDEs (Lynx) and B16s sound a little... limp.
After that, keep it simple. The wing-delete is the simplest mod that makes sense. Then go for good mags and tires, a brake upgrade if you can, from an EVO... (which would give you cool five-lug hubs), simple skirting if you still want it, but the GSR is a looker even when stock. Some fresh paint and detailing, and it's still a head-turner.
Personally, a clean, well-done car will attract looks more than a BOMEX-clad monster with questionable paint and taste.
Engine swap 4G63t.Lagyan ng Recaro seats,sound set up,K92 paint,lagyan ng bodykit.
Gawin mo din sa GSR maging convertable at the same time hard top na motorized.Parang Miata.
Ewan ko kung may nakagawa na nito ah.
If you won't sell it in the future... i think a top-down/convertible GSR will look nice.![]()
don't really like those lambo-doors. paano kung maliit ako?hehhe parang pampadali lang ng parking yan e.
Lambo-doors + roll-over = you're ****ed...
Besides, they're pretty expensive... expensive enough to buy you a complete vehicle set-up without them.
How about something just as cool? Shave the door handles off, and make the doors push-button activated (buttons hidden under the side mirrors).
