Originally Posted by
Release Information
Audi has just unveiled the 2008 R8 its first ever production supercar. Sales will begin in the first half of 2007 for the United States and Europe. The car has a 420 horsepower high-revving V8 engine and all-wheel-drive. It uses the mid-engine Lamborghini Gallardo platform, and will sell for around $100,000 positioning it squarely against the BMW M6 and Aston Martin Vantage. It features LED headlamps surrounded by LED running lights and indicators. LEDs are also used in the engine bay to make the impressive V8 visible even at night. Claimed 0 to 62 mph time is 4.6 seconds, though this number is likely conservative.
The sporty interior is dominated by a totally driver-oriented cockpit architecture, integrating the driver between the dashboard and the high centre console. The instrument panel above the console is angled slightly towards the driver. The flat-bottomed steering wheel is a typical feature of the sportiest Audi models, and also enables comfortable sports car entry and exit.
The sports seats are trimmed as standard in a Leather/Alcantara combination, or optionally in full leather. Alternatively, the R8 can also be fitted with bucket seats, specially developed by quattro GmbH. There is plenty of room for the two occupants, with comfort levels well beyond the norm of high-performance sports cars. There is space behind the seats to stow large bags, or even two golf bags. The luggage compartment at the front has a capacity of 100 litres.
With numerous trim variants and applications in Piano finish or Carbon sigma, there are few limits to the range of customisation options for the interior.
The drive train
At 7,800 rpm the 4.2-litre engine delivers 309 kW (420 bhp) of power output. Peak torque is 430 Newton-metres from 4.500 to 6,000 rpm. And no less than 90 per cent of this maximum torque is maintained consistently throughout a wide engine speed range from 3,500 all the way to 7,600 rpm. As a result of these qualities, the eight-cylinder power unit provides maximum thrust in virtually any driving situation.
The performance figures are equally impressive: the R8 accelerates from a standstill to 100 km/h in 4.6 seconds and reaches a top speed of 301 km/h.
The engine is a high-revving unit. The maximum engine speed is 8,250 rpm. The advantages of this principle are superior power output at high engine speeds and a smooth, eager responsiveness all across the revs range. Added to this are its agility, liveliness and engine sound, which is similar to that of a race car.
The Audi R8's dry sump lubrication another technology originating directly from motor racing provides the ideal basis for maximum longitudinal and lateral acceleration. It allows the V8 to be installed lower, thereby lowering the centre of gravity and further enhancing driving dynamics.
Two transmissions are available: a manual 6-speed gearbox or optionally the Audi R tronic sequential-shift gearbox, with a joystick gear-shift on the centre console and, most especially, the paddles mounted on the steering wheel. 'Shift by wire' technology provides for very fast gear-shifting and an outstanding power-to-weight ratio, allied to compact gearbox dimensions. The Sport mode, with its fast shifting, guarantees the absolute maximum in terms of driving fun. An automatic mode can also be selected.
The car is fitted with permanent four-wheel drive, which distributes the power variably to the front and rear axles by way of a viscous clutch. On the Audi R8 the legendary quattro system is adapted to the axle load distribution typical of mid-engined cars.
The chassis
The chassis features forged aluminium double wishbones at the front and rear. At the front they are triangulated, while at the rear the top one is triangulated and the bottom one is a triangulated wishbone with a track rod. This provides for optimum wheel control, and is a geometry which has proved itself to be the ideal solution in delivering agility, maximum steering precision and precisely defined self-steering characteristics.
Direct, hydraulic rack-and-pinion steering provides optimum feedback to assist the driver.
The spring and damper set-up is stiff in order to deliver maximum driving dynamics, while still providing a quite astonishing level of ride comfort. This is particularly true when the 'Audi magnetic ride' adaptive damper system is chosen as an alternative to the standard gas-filled shock absorbers.
The reason for this is that these shock absorbers employ an innovative technology. Instead of the conventional damper fluid, a magnetorheological fluid is used in other words, a fluid whose viscosity can be influenced by an electromagnetic field. This effect enables the damping characteristic to be influenced electronically at will and instantaneously, by applying a voltage to the electromagnets.
Audi magnetic ride uses this property to deliver the correct damping forces in every driving situation, thus optimising ride comfort and driving dynamics. A computer equipped with sensor technology determines the prevailing driving situation in a matter of milliseconds. Drivers can choose from two driving programs depending on whether they want to drive in a highly sporty style with the magnetorheological fluid adjusted to a low viscosity or with the emphasis more on ride comfort.
The Audi R8 is fitted with 6-arm 18-inch wheels as standard, and can optionally be ordered with 19-inch wheels. The 235/40 size tyres at the front and up to 285/35 at the rear provide the necessary road-holding. This tyre configuration also ensures that this mid-engined sports car is always able to translate the dynamism of its drive train and chassis into optimum grip and maximum lateral dynamics.
The mid-engined sports car's long wheelbase and extremely low centre of gravity ensure that it always retains maximum stability, resulting in superb agility, finely attuned responsiveness to any driver input, and high levels of safety.
Equipment and trim
Even the standard equipment of the Audi R8 meets the high demands of customers in this segment. Xenon plus lights, LED rear lights and daytime running lights, 18-inch aluminium wheels, an audio system with 7-inch monitor, an anti-theft alarm and Leather/Alcantara interior trim are just some of the items on the extensive list of standard features.
The range of optional extras leaves virtually nothing to be desired. A Bang & Olufsen sound system, featuring an output of 465 watts and 12 specially designed speakers, delivers surround sound of the highest standard. A microphone-based vehicle noise compensation system adjusts audio levels to changing road conditions and speeds.
The acoustic parking system and a rear-view camera help the driver to manoeuvre into even the tightest of spaces. The radio/navigation system plus, featuring a large-format colour monitor and MMI keypad, combines extensive functionality with extreme user-friendliness.
A range of coordinated and ideally combinable design and leather trim packages from Audi and from quattro GmbH can turn any R8 into the customers personal dream car.
The wheels range offers design alternatives in sizes of 18 and 19 inches, fitted with 235/35 size tyres at the front and up to 295/30 at the rear. A total of eight exterior colours are available, from Ibis White to Phantom Black, pearl effect.
The craftsmanship
The Audi R8 is being built on a small-lot production line in a specially constructed new block at the Audi plant in Neckarsulm. The entire production process from the bodyshell construction to final assembly is organised in the same way as a craft workshop. Small teams of specialists accompany every step of production, subjecting every part and component to intense scrutiny. This ensures that every one of the maximum of 15 cars per day built will more than match the customary high quality standards of the Audi product range.
