Results 11 to 20 of 22
December 15th, 2004 03:04 PM #11
punta ka na lang kay mang mario(?)
aircon specialist
malapit sa may SM north edsa. highly recommended po siya.
December 15th, 2004 08:17 PM #12
Mura lang pag bearing, basta wag lang tatamaan yung shaft ng compressor.
- Oct 2007
- 30
October 11th, 2007 11:29 AM #13hi po... im also having the same experience, may whistling, at hindi lang basta whistling, super lakas na whistling.. a mechanic also told me na compressor yun.. he already overhauled it, changed the pulley bearing..ganun pa rin..so compressor nga raw talaga.. ano suggestions on what i should do? palitan ko nga ba ng compressor un? may alam po ba kayo malapit na aircon mechanic sa angono, rizal? east of metro manila.. tnx!!!!!!
October 11th, 2007 01:28 PM #14
ako naman po meron din whistling sound...
pero kahit wala akong aircon may tunog sya...
hihina lang yung tunog pag bibitawan ko unti unti gas...
sometimes naman walng tunog.
hindi ko alam kung bakit.
minumulto lang ba ako? napiplip?
or kapareho lang nila sa compressor ang problem?
October 11th, 2007 04:34 PM #15
I experience whistling sound in the Aircon. but the cause was just a leaf stuck on the aircon radiator. the sound actualy sounds good because it sounded like a plane's turbine, and was louder than our turbo.
October 11th, 2007 07:34 PM #16
yup, compressor nga yan. have heard the same humming/whistling sound when i turn on my a/c, then nawawala pag off-on ko uli. now, nawawala na ang lamig. have to bring my car to denso for check up. malamang replace compressor ako.
- Mar 2009
- 4
March 13th, 2009 10:38 PM #17i have the same problem...my 93 gli corolla e whistling sound pero random ang paglabas nya.
Pagtumatakbo ang oto minsan tutunog pag pinatay ko aircon nawawala, tapos pag on ko ulit aircon wala na..minsan naman pag tumunog e ire-rev ko lang nawawala din ..ang masama e ito...pag pinapatay ko makina me parang pahabol pa na sipol...
ang tunog e sa bandang gitna ng makina... ito pala ang case ko...medyo 2 months na butas ang air filter hose ko pero tinape ko lang..sabi ng mekaniko e nadumihan daw yung intake na kinakabitan ng air filter hose...tapos isprayan ko lang daw ng "grease away" e kaso wala ako makita sa Ace hardware at sa handyman...san kaya ako makakabili nun at ano ang alternative kung walang available na "grease away"?
madumi kaya ang fuel injector ko? ano kaya ang magandang panlinis para sa EFI?
HELP po....naiinis na ko sa sipol na tunog na to...di po sya galing sa compressor ng aircon or sa ano mang belt or fan...
thanks and more power
- Mar 2009
- 6
March 14th, 2009 09:28 PM #18try checking yung adjuster pulley may bearing un, kng sira na tlga ung bearing nun sa pulley cracking sound na ang maririnig mo ndi na whistling sound bka masira din ung leeg ng compressor mo.
- Mar 2009
- 4
March 15th, 2009 08:09 PM #19
- Apr 2009
- 3
July 1st, 2009 10:10 AM #20Hi! I have the same problem.. where can I see that valve for the air??? maybe i can try to adjust it. Napalitan ko na kasi mga belts and checked the compressor and aircon but still the whistling sound is still there. Maybe we have the common problem.. My car is 2003 ford lynx ghia... thanks in advance!
My Ford SYNC just updated itself. Anyone here knows what was updated?
2023 Ford Everest Owners Thread
