Results 1 to 10 of 11
- Jun 2008
- 12
May 4th, 2013 12:38 AM #1Hi to all,
I have a weird problem experience sa Honda Civic 2003 ko. I usually encounter the problem during traffic (pag 1st/2nd gear lang due to traffic jam). Problem is bigla nalang nawawala ang lamig, as if parang fan lang umaandar. And then while nawawala yung lamig, tumataas yung RPM kahit fully stop ka pa sa traffic. Normal/idle while at stop is say 800-900 RPM, tumataas po siya ng up to 2000 RPM.
Ang ginagawa ko, pinapatay ko aircon then magda-drop sa normal yung RPM, after mga say 10-15 minutes, pag i-turn ON ulit yung aircon, okay nanaman ang lamig at everything is back normal. Madalang lumabas yung issue pero I know na may di normal sa car ko. Problem is pag dinadala ko sa casa hindi lumalabas ang issue so feedback sakin is normal lang lahat at walang problem. Ilang beses ko narin pinalinis sa casa pero naee-encounter ko parin yung issue na yun.
Napansin ko lang pag maiinit ang panahon at pag traffic dun lumalabas. Any advice please...
Thanks in advace.
May 4th, 2013 06:39 AM #2
sir baka po nag ooverheat kayo... check nyo po rad. baka clogged na... and your aux fan...
- Oct 2009
- 2,271
May 5th, 2013 07:05 PM #3nag hihightemperature na AC mo..
ganito...pa flashing mo lahat ng tubo ng aircon mo..
palitan filter dryer..flashing din ung conderser baka barado nadin...
palitan ng expansion valve ung dual line na expansion valve ha..kasi minsan single lang kinakabit nila.mahina lumamig..
naka kabit un sa evaforator ung expansion valve,,
saka lagyan ng freon..arround 2,5k aabutin nyan...ganyan din nagiging sakit ng tsikot ko kapag nag hihigh temp..
subukan mo buhusan ng tubig ung condenser ung katabi ng radiator..condenser un..kapag nagloloko ung aircon mo babalik ang lamig niya...or check mo nadin ung condenser fan mo baka naman mahina ng umikot..result hightemp..or nahihilaw ung lamig...
nagpapatay sindi ba ung compressor? may sound na click click..
May 5th, 2013 08:10 PM #4
May 5th, 2013 08:57 PM #5
Happened to my 2004 Honda Civic before. Nakita ng technician na may intermitent circuit sa clutch solenoid assembly ng compressor at dahil sa sobrang init bumubitaw ang clutch dahil walang current sa coil nito. Pinalitan nila ng clutch assembly ang compressor at di na umulit ang problem nito.
- Jun 2008
- 12
May 6th, 2013 05:22 PM #6Sir, pwedeng malaman yung shop na naka solve ng problem mo before. Since 2004 yung sayo baka nga na-didis-engage yung clutch (kung di ako nagkakamali, yun yung "click" na naririnig natin pag nag-switch ON tayo nga A/C di ba). And how much did it cost you parts & labor.
Thanks for sharing your experience.
And salamat din sa ibang nag post ng comments...very helpful indeed.
- Jun 2008
- 12
May 6th, 2013 05:25 PM #7Sir, pwedeng malaman yung shop na naka solve ng problem mo before. Since 2004 yung sayo baka nga na-didis-engage yung clutch (kung di ako nagkakamali, yun yung "click" na naririnig natin pag nag-switch ON tayo nga A/C di ba). And how much did it cost you parts & labor.
May 6th, 2013 05:47 PM #8
Pa cleaning mo muna before ka magpapalit ng ano-anu
Sent from my iPad using Tapatalk 2
May 6th, 2013 06:31 PM #9
Agree with shadow.
sa akin naman, bumagal ikot ng aus fan kaya pag hgh rpm na ako nawawala lamig nag high pressure yung compressor, pag low rpm umo-ok naman sya. until such time na nagrelease na ng refrigererant yung compressor. ayun i found out na ang problema pala is yung ausxilliary fan.
pacleaning mo muna, makikita nila yan kung ano problema. saan ka ba banda may mahusay na AC repari shop sa Camella Molino.
- Jun 2008
- 12
May 7th, 2013 10:14 PM #10
In my car idle on coldstart was 2k high need 2 to 3 m3 mins to be restarted the engine to get the...
high idle RPM at engine start
