Quote Originally Posted by miked View Post
a cheaper way to eliminate or shoot the trouble (without doing something on the A/C system): tanggalin engine radiator at bugahan ng malakas na spray ng tubig ang A/C condenser (from the inside out para declog ang fins neto). tandaan wag masyado malapit para di naman masira ang fins. kahirap kaya suklayin sa dati netong hairstyle. kung malaki ang pagbabago, then probably e low heat transfer lang sa condenser due to dirt, grime, insect, etc. buildup....yung thermoswitches mo or sensors for the fans, etc. seems to be ok.
the air contains moisture at once nagcontact ito sa evap ng auto e nagcocondense ito. freezing point ng tubig is at 0 deg celsius kaya dapat di umabot sa ganitong temp yung evap kundi magaccumulate ang frost sa evap at mag-act na ito as insulator. lesser cooling na mangyayari.
the pressure reading sa low side ng A/C is at the neighborhood of 30 psi, magkalapit lang for R12 & R134 (with a corresponding saturation temp of just above zero deg celsius)
ang comfort air conditioning ay nasa 22-24 deg celsius usually.
yung thermometer ko sa sasakyan (nabili ko ng P88 sa Daiso, hehe) reads 30 deg celsius. pero i doubt its accuracy. tsaka kelangan ko na rin magpalit ng tints sa kabayo ko.
Evaporator temp is around -5deg celsius or lower. It will freeze if condensate is trapped usually by dirt or not enough air can pass due to clogged cabin filter. air at vent should be at 10deg celsius or lower to have that 20 to 25 deg celsius real feel
