Hello there fellow tsikoteers, I just want to seek an advice regarding my L300's aircon compressor. I will just ask if repairable ba ang shaft seal ng SD 7 sa compressor??? And if not, how much is the brand new??? Can you recommend any aircon shops yung hindi nanloloko, and kung kaya pang maayos 'yung shaft seal??? Thank you very much...
, it has to be replaced. the seal component resposible for the sliding surfaces are made of graphite and do not usually cause a leak unless touched by bare hands on the sealing surface. believe it or not, as thin as a fingerprint can cause it not to seal properly. however, the neoprene component that seals the shaft starts to develop leaks after an extended period of time. the airconditioner needs to be "exercised" every now and then to assure the seal lubrication and integrity.
