Results 1 to 18 of 18
    Quote Originally Posted by albert_b
    Kapag umaandar, may wind na nag-coo-cool down ng radiator mo ... check mo nalang if yung fans mo ok pa. Maybe you might want to add some coolant na din.
    I just had my fan changed (direct belt driven ito). Also, am using Caltex Coolant. Pag sa gabi, less than 1/4 ang temp gauge. During hot days, nasa 2/5 (near half ang gauge).
    Baka I need to spray / clean the aircon radiator (what's it called pala? lolz). Baka may mga dumi na nakabara. Kcboy, you can probably do this, or better yet, have your engine washed and radiator cleaned externally.
    Pero weird talaga, whenever my 2nd aircon is on, medyo humihina, pero pag 1 aircon lang on, kahit naka idle, malamig...
    Sep 2004
    Quote Originally Posted by Dieseler
    I think ang normal na thermometer reading should be a little less than half the guage ... pwedeng mag-start ng masmababa pero after a couple of minutes dapat almost midway ang needle.
    Try mo nalang ipalinis yung evaporator (tama ba?) ng a/c mo. And while at it, get an engine wash narin :-)
Uncool A/C
