Results 1 to 8 of 8
February 11th, 2010 03:02 PM #1
Guys any idea on my townace 2cTurbo engine, ang problem is pag start ko after 3 to 5mins bigla na lang riseup ang temp gauge ko to full as in sa red mark na. After ko itakbo about 45mins check ko tubig and reserve tank ok nman at no signs naman sa engine noise at normal naman ang hatak at takbo nya. Ang pinalitan ko pa lang is sending unit nung temp gauge pero ganun pa din. Any comments mga masters dyan? thanks in advance.
February 11th, 2010 03:14 PM #2
sorry mods sa multiple post, nag loloko internet eh.. paki delete na lang po.. sorry ulit
- Jan 2010
- 283
February 11th, 2010 04:45 PM #3
February 11th, 2010 10:16 PM #4
nag wire na din ako sir ng diretso, from sending unit direct sa wiring sa likod ng panel gauge(nakita ko yung isang wire para sa sensor) ganun pa din eh..
February 12th, 2010 04:57 AM #5
- Oct 2009
- 72
February 20th, 2010 07:41 AM #6If after 3-5min your temperature gauge rise to the red line, try removing the wire from the temperature sensor, if it still on the red mark, then you have a shorted at the panel meter, but if it goes down, then you have an IVR (instrument voltage regulator) problem, which is located on the panel meter. Some panel meter have both temp gauge and fuel gauge connected on this IVR, but others have independent IVR.
February 22nd, 2010 12:37 AM #7
sir pag tinangal ko sa wire sa sensor pag nasa red mark na bumababa naman.. wala ako idea regarding IVR, napansin ko lang sa likod ng panel is may naka umbok na malaking plastic na parang relay, yun kaya iyon? kelangan ba yun palitan?
February 22nd, 2010 03:03 PM #8
Monk-owned R53
