Results 1 to 10 of 18
Registered User
- Sep 2011
- 1,313
November 12th, 2012 08:14 PM #1good day mga expert's !
ano ba magiging effect sa sasakyan kapag ini istart ng walang heater , anu ang possible masira kapag palaging ganito ?
napansin ko kasi yung relatives kasi namin ini istart niya palagi yung sasakyan ng wala ng heater heater , need na need pa nanam ito lalo kapag umaga :hammer:
kahit masakit sa luob ko hindi ko naman mapag sabihan , kasi nakaka tanda sa akin ..
Ride is 2.5 D4d .
- 54,286
November 12th, 2012 08:51 PM #2in my opinion..
may sasakit lang ang luob. yun lang.
mabilis ang "heater" ng innova. ilang segundo lang. baka yan ang rason kung bakit akala mo ay walang heater-heater..
diesel engines need three things to fire up: fuel-air mixture, pressure, and heat. once running and the engine is hot, one does not need a heater to start the engine again if you turn it off. the cylinder walls are already hot. all one needs then, is fuel-air and pressure.
so, anong mangyayari kung walang heater ang cold engine ? hindi siya mag-start. do you need a heater to re-start a hot engine? nope. just take a look at how jeepney drivers re-start their hot engines: tinutulak lang.Last edited by dr. d; November 12th, 2012 at 08:54 PM.
November 12th, 2012 09:02 PM #3
cmiiw, di ba kailangan lang ang heater pag ayaw mag-start (malamig ang makina)? o baka ito yung katulad sa L300, yung key light sa gauge panel e kailangan muna mag-ilaw ng green (not sure. di ko na maalala kung red o green) bago mo pwede start ignition. saka tingin ko ok lang yan basta wag muna paandarin. as in start nya lang muna yung kotse para maginit.
November 12th, 2012 09:44 PM #4
para sa cold climates na lang yan heater plugs, gaya sa korea o japan. sa pinas, maliban na lang kung nasa baguio ka ng december, sa mga new diesel engines na (crdi, o d4d) di na need yan sa tropical climates kasi maganda atomization ng fuel kaya compression heat lang start na agad. yung mga lumang diesels yun ang need ang heater plugs.
November 12th, 2012 10:06 PM #5
mga sir bkt ung auv namin pag umaga kailangan 50 seconds para mapa andar lang
kailangan naba palita heater?
November 12th, 2012 10:17 PM #6
- Aug 2005
- 553
November 13th, 2012 12:14 PM #8Direct injection fuel systems operate at a much much much higher pressure than old mechanical injectors.
- Jan 2008
- 4,726
November 13th, 2012 12:21 PM #9
- Nov 2009
- 3,509
November 13th, 2012 12:35 PM #10Lahat po ng diesel engine may glow plug. Modern CRDI do have glowplugs pero quick glow. Dimo lang pansin pero saglit lang ang operation nito compared sa old school na may timer na mas matagal.
[QUOTE=ice15;3387274]medyo disappointing itong Sealion 5 No front sensor either Manual Seats...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
