Results 1 to 7 of 7
- Mar 2005
- 233
September 25th, 2008 12:24 PM #1patulong mga peeps baka may idea kayo kung ano problema ng kia carnival ko.
pag start malamig ang aircon pero after a few minutes hindi na gumagana ang compressor. variable ang tinatagal, kung minsan 20, kung minsan halos isang oras bago mawala yung lamig. suspect ng technician yung relay kasi pag nirekta yung compressor gumagana naman at saka pag namatayan ng aircon, pag tinanggal yung relay tsaka ibalik after a few minutes gumagana ulit. kakarga lang din ng refrigerant.
thanks in advance
- Jul 2008
- 13
September 25th, 2008 05:05 PM #3[SIZE=3]Better bring your van to a trusted technician/shop before other parts would be affected. And it would be costly.[/SIZE]
September 27th, 2008 11:25 AM #4
September 27th, 2008 11:25 AM #5
- Mar 2005
- 233
September 27th, 2008 11:44 AM #6thanks for the replies guys. yesterday i had the contact points cleaned with contact cleaner spray and so far the aircon is working well again
- Oct 2008
- 366
November 8th, 2008 03:02 PM #7Check maybe the line is freezing. Then when you off your a/c for a few minutes then on it again if its cool again then better check you thermostat. Its not functioning. The compressor is keep on running without tripping then the line starting to freeze and lose the coolness.
6-11k. depende sa brand.
2016/2017 Isuzu MU-X
