Results 1 to 9 of 9
- Apr 2014
- 231
June 27th, 2017 02:37 AM #1I've stumbled upon this post trying to find answers on my problem
"there are two fans for corolla, one is radiator fan and the other is a condenser fan.
when the engine coolant is still cold and the aircon is on, both radiator fan and condenser fan runs at half speed
when the coolant is around 90 degrees celsius and the a/c is off, the radiator fan runs at full speed and the condenser fan stays off
when the coolant is hot and the airconditioner is on, both radiator and condenser fan run at full speed. "
My condenser fan is not consistent ... sometimes it runs full speed, sometime half speed .. Even when the engine is already hot after running around the city ..
When engine to cold and ac on, the condenser fan sometime run at full speed ... When engine is hot, the radiator fan fan at full speed, but the condenser fan sometimes run half speed and sometime full speed ...
Is is this normal ?? Or do I need to replace the condenser fan ??
June 27th, 2017 02:59 AM #2
sensor ok? wiring ok?
- Apr 2014
- 231
June 28th, 2017 06:12 AM #3
- 54,291
June 28th, 2017 08:02 AM #4
- Jul 2010
- 165
June 28th, 2017 08:26 AM #5
- Apr 2014
- 231
June 29th, 2017 07:40 AM #6
June 29th, 2017 10:24 AM #7
Pwede palitan ng motor lang yan around 500 to 1000 depends sa brand na kukunin mo
Sent from my ASUS Zenfone 3 using Tapatalk
- 54,291
- Apr 2014
- 231
June 29th, 2017 11:57 PM #9hindi nman mag overheat kasi nung nabutas yung top ng radiator ko dahil nag clogged, ang unang una ko napansin ay nag full speed ang condenser fan at radiator fan para hindi mag overheat ang makina .. ngayon na maayos na ang radiator ko, bagong overhaul .. balik to normal na nman yung condenser fan .. minsan half speed, minsan full speed ..
Nagtataka lang ako dahil ang pagkaka alam ko, kapag mainit na ang makina at full speed na ang radiator fan .. diba dapat full speed rin ang condenser fan .. yung akin kasi hindi eh .. minsan nag full speed speed nag ilang seconds lang tpos balik to half speed na naman ... tapos off .. after ilang seconds .. on nanaman pero half speed .. mayat maya full speed nanaman ng ilang seconds ..
Baka cguro ito yung dahilan na hindi lumalamig yung aircon ko kapag steady sa traffic kasi hindi nag full speed yung condenser fan kahit mainit na ang makina at tanghaling tapat sa traffic ..
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
