Results 1 to 3 of 3
- Feb 2007
- 79
November 15th, 2009 02:53 PM #1My car is nissan lec. Saan ba makikita ang thermostat nito? Gusto ko kasi i-check kasi I suspect na stucked up na. Thanks!
- Nov 2009
- 2
November 17th, 2009 04:34 PM #2
it_online,
if you think it is stuck, you must be talking about a stuck open or stuck closed thermostat. the location for this component is nowhere but where your upper radiator hose connects to the engine, otherwise, if your car has reverse flow cooling system, it will be on the lower radiator hose where it connects to the engine block
- Oct 2009
- 44
November 19th, 2009 06:17 AM #3Follow mo lang ung big hose ng radiator mo. Then you will see some sort of housing that has 2~3 wires on it depending on model and brand. That's your thermostat housing. Temp is on the exit and thermostat on entrance to engine block cooling.
Babala! Sarado at Ginagawa mga south bound flyovers along c5. Medyo mabagal Ang daloy kanina Ng...
Traffic!
