Results 1 to 13 of 13
    Apr 2008
    Lagi na lang problem ito ng radiator ko. It's not a major problem since stable naman ang temperature niya at di naman nag-ooverheat. it justs pests me off..
    Dati, tubig lang na galing sa refilling station ang tubig ng radiator ko. then when i found out about coolants (prestone) 3 months ago, finlush ko yung radiator ko. dun ko nakitang maraming kalawang.
    nung ipina-top overhaul ko yung makina last week, finlush ng mechanic ko yung radiator ko. maraming kalawang ulit. then nilagyan na muna namin ng water without coolant to check if there is any problems after namin i-top.
    tapos chineck ko ulit yung radiator ko after 2 days. kalawang ulit yung tubig.
    ano kaya cause nito? do i need to change my radiator?
    Apr 2004
    if you don't overheat, no need to do anything expensive like changing the rdiator. the rust may be coming from the block, the radiator, or the waterpump. coolant has anti corrosive properties so it's a good idea to always use it after flushing the rad/block a couple times.
    aluminum block engines don't normally rust, but cast iron block engines do. you can also try overhauling the rad, mura lang naman ito. then flush again until the water clears. then put coolant. and when you flush, make sure you disconnect the intake/return hoses from the block to the rad so the water from the block comes out (it will look rusty). don't forget to put them back before you start.
    the rust you are seeing now is the accumulated rust during all those years that you had only plain water in your engine. when you started using coolant additives and when you flushed it, the rust started to flake off from the engine and radiator. that is normal because coolant additives also have a cleaning effect, it will clean the engine of rust. the thing to do is to just continue replacing the coolant until such time that you do not see any more rust, maybe do the change once a month. or you can flush it again. after that make sure you have the right mixture of coolant additive and water to prevent the engine from corroding.
    but you said you had stopped using coolant again? that is wrong. rust will again build up in the engine and pretty soon something will get eaten up, like the radiator.
    Jan 2009
    Flush it again and then use distilled water + coolant in a 50-50 solution. You can use distilled battery water sold in all gasoline stations.
    I did this to my big bike which also have the same problem as you have. My problem was solved.
    Tap water directly from the faucet is hard water and the chemicals in it promotes oxidation inside your coolant system, causing rust and other things.
    Dec 2007
    I'd stay away from this so-called distilled battery water if I were you, especially if you won't be using it inside the battery. I hate to think what it will do to your radiator and whole cooling system.
    Distilled water is odorless and tasteless. The "distilled" water that gas stations sell seems to contain some kind of electrolyte (maasim, e).
    I suggest you buy from reputable brands of distilled water like Wilkins.
    My 2 cents.
    Aug 2004
    Quote Originally Posted by woohoo View Post
    My 2 cents.
    Hmmm....baka nga hindi purong distilled water yung nabili mo....kung maasim, acidic ibig sabihin....baka hindi nahugasan yung lalagyan at nahaluan ng sulfuric acid (battery electrolyte). O baka ang nabili mo eh sulfuric acid solution talaga
    Wilkins is fine....also R.O. water (you can ask the refilling station to test it when you buy using their TDS meter.....R.O. water is 0-10 ppm TDS...
    tama, stay away from that distilled water sold in gas stations. besides being of doubtful origin it is also expensive.
    try mo wikins distilled water.
    Sep 2004
    AFAIK, gasoline stations sell 2 different types of water: the so-called "distilled" and electrolytic water. Magkaiba sila, although doubtful talaga kung distilled nga yung former. The latter naman, if you accidentally get some splashed on your skin, you get an itchy feeling. Parang bumubula pa nga sometimes pag natapon sa concrete floor, hehehe.
    Mas mura yung distilled water ng Absolute kesa sa Wilkins, kaya yun ang binibili ko, hehehe.
    Jan 2009
    I stand corrected. Any source of distilled water will be fine for engine coolant use. Also, as I've mentioned, I used 50-50 solution because that is what's recommended for my bike. Check your owner's manual for the correct proportion.
    Absolute rin gamit ko even for flushing. Some have tried the SM Bonus distilled drinking water na mas mura pa.
    Jun 2007
    Guys,
    Can you recommend a reputable radiator overhaul shop? The ones I see look like "cheapy-cheapy" repair shops and I'm not confident of their service.
    A shop around the Mandaluyong, Pasig or San Juan area is preferred.
    Thanks.
    Apr 2009
    hi.... pareho lang ba if i use mineral water, puede rin ba yun sa radiator and battery? sa battery kailangan ba battery solutin na matapang or plain mineral water puede na?
    saan may shop na mahusay sa pag radiator overhaul..
    thanks
    Sep 2004
    Mineral water is different from distilled water. As the name implies, may certain minerals pa rin ang former.
    Don't use it to top off the battery. Use battery fluid (electrolyte) or distilled.
Rusty Radiator
