Whenever my A/C is turned on, patches of fog or mist appears on the same spot of my windshield - middle bottom area. Lumalaki ng lumalaki hanggang mahirap na visibility. Sa labas yung fog. I use my wiper to clear it off pero bumabalik. It's not even very cold inside the car. Tama lang. The only way to quickly get rid of it is to turn off the A/C and roll down the windows. This can happen no matter what the temp is outside. May nakaexperience na ba ng ganito? How do you fix this?
Actually, hindi pa masyadong malamig inside. The AC is not set too high. If I turn it down, maiinit na. Other cars na masmalamig pa on the same day, wala namang ganun.
san ba location mo? usually nangyayari yan pag mas malamig ang temperature sa labas kesa sa loob nang car..
na experience ko yan sa Baguio and Tagaytay.. dito sa Metro Manila pag malakas ang ulan sa gabi.. pero pag normal day at may araw pa.. hindi dapat mag fog yan..
ano ba sasakyan mo sir? mali lang ang vent nyan tignan mo lang sa may harap mo kung tama dapat sa muka nakaharap ung arrow... kung tama naman sira na yan foam nyan.. kaya ganyan yan kasi sumisingaw ang hangin... try mo lang takpan ng foam..
Thank you sa mga replies. Sa manila lang ako and it's an '01 rav. Im actually selling it pero gusto ko pagawa muna mga maliliit na things na ganun for better customer satisfaction. It's probably the vent nga. Dapat ba aircon specialist ang gagawa ng ganon?
^Most likely an aircon shop. Depending sa design, pero for sure you'll need to remove parts of the dash or the whole dashboard to access the vents. Pwedeng sira yung cable, or yung vent motor or worse, foam insulator.
Actually, nakaset na siya dun sa 1st icon. Di ko binabago ever since. I think sa vents yung problem as what others assumed. At least I know na what to look for first.
