Results 11 to 16 of 16
June 26th, 2013 02:32 PM #11
Yes, it still holds. Its idle control valve, local mechanics and stockman call it VCV
or vacuum control valve. Just follow that rubber hose the size of spaghetti for leaks.
Most of the time it just falls off for some reason so you have to put it back on.
Or replace for a new one.
You check it by covering the hose with your finger to feel if it sucks air.
If it sucks air then it works and simply put it back on.Last edited by mark_t; June 26th, 2013 at 02:38 PM.
- Sep 2011
- 22
July 1st, 2013 01:21 PM #12sir, na try nyo n po ba i pa check up ung injection pump nyo? kc palagay ko nan dun ang problema.. pwede pong barado na injector
mag kulang po ng supply ng fuel.
- Nov 2008
- 641
July 1st, 2013 06:22 PM #13Sir dr. d is correct. Based on your lastest comment, your idle up system is defective. Check your hoses going to the idle up mechanism for possible cracks, might be a faulty solenoid, or if still not, either your line is clogged or your diaphram is leaking already. Better have your car checked by a specialist
- Jul 2008
- 479
July 2nd, 2013 11:25 AM #14i also think the problem is with the idle-up system. it may be the hose or the idle-up mechanism itself.
- Sep 2010
- 181
July 4th, 2013 10:15 PM #15yun!!....thanks mga bros sa inputs nyo....baka nga sa idle up system, kasi nga pag nag aircon lang pumapalag at nag vibrate ng husto yung sasakyan eh...kung ang purpose ng VCV ay mag adjust ng idling pag nag ON na yung thermostat ng aircon, walang duda na dun na nga yun, kasi hindi tumataas masyado yung RPM gauge ko pag nag nag swtich on yung thermostat ng aircon, parang kinakapos sya ng fuel, kaya nag vibrate..hayss,sana yun na nga ang problem, nakakahagas pag ganun yung Sportivo ko...
...maraming maraming salamat mga bros...but any comments are still welcome...
- Sep 2010
- 181
November 9th, 2013 04:18 AM #16mga bros...ok na...idle up switch nga, stuck up, pina adjust ko lang, ok na uli...thanks uli mga bros...
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
