Results 1 to 20 of 21
    Aug 2005
    help naman po....yung radiator ng CR-V ko namamawis na sa pagitan ng plastic top and yung kinakabitan nito(wala naman siyang malakas na tagas). A guy from the radiator shop told me na palitan na sa tanso yung plastic....I heard there are ready-built copper tops....Question lang....do i replace the whole radiator or yung top na lang?ano maganda brand ng replacement radiator....namamahalan kse ako sa charge nung guy...3k para sa top na tanso...thanks
    few years ago, on my civic, it used to be P1500 for the copper top replacement ... but copper price has risen about 3 times its cost in 2005 (as indicated by the cost of electrical cables made of copper) ... so P3000 might be reasonable today ... copper top is still the least-cost alternative
    reliable din naman ang copper basta magaling ang gagawa ... palit ng cap at pipinturahan din ng black para mukhang orig
    Jul 2006
    While you're at it ipa-pressure test mo na rin cooling system mo to find other leaks. Baka hindi lang yun ang weak spot, so it would be useless to fix that when there are other problems too. Good luck.
    change the whole thing, evercool brand.....3-4k lang yun whole radiator..
    Jun 2006
    Kung Denso ang radiator mo, look for them sa yellow pages, they have replacement parts.
    Nov 2007
    bossing yun top na lang palitan nyo kasi yung sa mb100 namin nagkaganyan din cguro 2005 nun pero ngayon ok pa din
    Aug 2005
    thanks sa input nyo...i already inquired r.e. evercool radiator....nasa 7k yung pang crv a/t....may denso na copper top ba na nabibili....cge, will wait for your further advices...
    Dec 2007
    walang copper ang Denso... They will replace it with Plastic din po... Ang advantage po ng plastic is 1st parang OEM parin 2nd there is a reason kung bakit plastic yun... kasi pag sobrang init na talaga puputok yung plastic and will save your c. Head....
    Sep 2004
    ^^^ I seriously doubt that theory. Sabi-sabi lang yan. Yung Accord ko, several times ng nag-overheat. Nasa redline na talaga. Pero, buo pa rin yung plastic top ng rad, ni wala man lang signs of cracking. Intact pa rin yung pagkakapit ng metal teeth dun sa plastic top.
    Am using an Evercool now, bought from and installed by Speedyfix.
    Apr 2005
    just have the plastic top replaced. PM mo si zeagle of coolmate/denso pasong tamo.
    Aug 2005
    sori for the stupid question pero pano po mag PM dito sa tsikot
CR-V 99 Radiator problem
