Results 1 to 10 of 21
- Aug 2005
- 183
January 9th, 2008 01:06 AM #1help naman po....yung radiator ng CR-V ko namamawis na sa pagitan ng plastic top and yung kinakabitan nito(wala naman siyang malakas na tagas). A guy from the radiator shop told me na palitan na sa tanso yung plastic....I heard there are ready-built copper tops....Question lang....do i replace the whole radiator or yung top na lang?ano maganda brand ng replacement radiator....namamahalan kse ako sa charge nung guy...3k para sa top na tanso...thanks
Tsikot Member Rank 4
- 2,716
January 9th, 2008 01:44 AM #2few years ago, on my civic, it used to be P1500 for the copper top replacement ... but copper price has risen about 3 times its cost in 2005 (as indicated by the cost of electrical cables made of copper) ... so P3000 might be reasonable today ... copper top is still the least-cost alternative
reliable din naman ang copper basta magaling ang gagawa ... palit ng cap at pipinturahan din ng black para mukhang orig
January 9th, 2008 04:17 AM #3
While you're at it ipa-pressure test mo na rin cooling system mo to find other leaks. Baka hindi lang yun ang weak spot, so it would be useless to fix that when there are other problems too. Good luck.
January 9th, 2008 09:23 AM #4
change the whole thing, evercool brand.....3-4k lang yun whole radiator..
- Jun 2006
- 2,605
January 9th, 2008 10:06 AM #5Kung Denso ang radiator mo, look for them sa yellow pages, they have replacement parts.
January 9th, 2008 10:28 AM #6
bossing yun top na lang palitan nyo kasi yung sa mb100 namin nagkaganyan din cguro 2005 nun pero ngayon ok pa din
- Aug 2005
- 183
January 10th, 2008 01:15 AM #7thanks sa input nyo...i already inquired r.e. evercool radiator....nasa 7k yung pang crv a/t....may denso na copper top ba na nabibili....cge, will wait for your further advices...
- Dec 2007
- 13
January 10th, 2008 08:57 AM #8walang copper ang Denso... They will replace it with Plastic din po... Ang advantage po ng plastic is 1st parang OEM parin 2nd there is a reason kung bakit plastic yun... kasi pag sobrang init na talaga puputok yung plastic and will save your c. Head....
January 10th, 2008 09:30 AM #9
^^^ I seriously doubt that theory. Sabi-sabi lang yan. Yung Accord ko, several times ng nag-overheat. Nasa redline na talaga. Pero, buo pa rin yung plastic top ng rad, ni wala man lang signs of cracking. Intact pa rin yung pagkakapit ng metal teeth dun sa plastic top.
Am using an Evercool now, bought from and installed by Speedyfix.
January 10th, 2008 02:00 PM #10
just have the plastic top replaced. PM mo si zeagle of coolmate/denso pasong tamo.
Suzuki JIMNY [merged threads]
