Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
    Aug 2012
    #21
    okay lang yan. importante lagi na lang check ang coolant level para wag mag-overheat.
    isa sa longest na nabasa ko sa forum is 4 years na car, 1-cm coolant level lang ang nabawas. very good condition sigurado ang cooling system nun.
    Aug 2005
    #22
    Quote Originally Posted by red_one View Post
    If you are losing coolant there are several things you need to check:
    1. Hoses/clamps
    2. Radiator cap & Filler neck
    3. Reservoir cap
    4. Drain plug seal.
    A perfectly sealed radiator loop will not loose coolant.
    Try running the engine and open the radiator cap. If there's a lot of bubbling then you may need to check your cylinder head.
Radiator and Reservoir still losing water after cleaning
