Results 1 to 10 of 12
- Apr 2007
- 11
April 26th, 2007 11:59 PM #1Hi, im new and just registered with this "fun club" hope i got to enjoy this. Came into this site when i was searching for some solutions and informations on how i can solve the aircon problem with the L300 Versa Van model 2004.
1 week ago, na i transfer na ung blower sa ilalim sa harapan, at first it was OK and sus malamig nga kahit bukas nga ung side door feel mo ung lamig...kaso nga lamang, last monday biahe ko pangasinan then to bataan. In the morning it was OK, but starting 11am until about 4pm....sus ginoo, mas mabuti pang magbukas ng bintana.
Knock...Knock....anybody got a better idea on how to solve this problem??? Any suggestion is most welcome.
By the way, im new, i dont know if im posting this message correctly.....nursery pa lang ko sa IT e....hehehehe....Thanks a lot!!!
(P.S....this is same message i posted as "testtrack" mukhang m ali ata dun....dito ata dapat...hope its correct this time!!!)
- Apr 2007
- 11
May 1st, 2007 12:04 AM #3Thanks for all the advise.....i had it check with another repair shop....and only paid Php250 for labor all the problem was solve and magjacket ka pag sumakay ka....it has been 3 days and so far so good. Now, alam nyo ano ginawa?????........1. binawasan ung freon level from 60 down to 40....according to the repair shop pag denso airconditioners daw dapat hindi sinasagad ung freon level para daw makahinga...yan daw ang ugali ng DENSO (ewan ko pero lumamig eh so baka tama cya heheheh)....2. tinangal ung filter sa harapan bago mag evaporator (this is the 3by3inch filter)....3. we paralyzed the fresh air effect by sealing the vent which goes thru behind the right side headlight in order to minimize pollution sa evaporator....we were just reminded to check and clean the evaporator every six months (no problem at all with me). Now, even at the peak of the heat level 1 lang ang ginagamit. Sa likod naman level 2 lang ok na.....so for info to others hope this will also help you later....thanks and more power!!!
- Apr 2007
- 11
May 1st, 2007 12:04 AM #4Thanks for all the advise.....i had it check with another repair shop....and only paid Php250 for labor all the problem was solve and magjacket ka pag sumakay ka....it has been 3 days and so far so good. Now, alam nyo ano ginawa?????........1. binawasan ung freon level from 60 down to 40....according to the repair shop pag denso airconditioners daw dapat hindi sinasagad ung freon level para daw makahinga...yan daw ang ugali ng DENSO (ewan ko pero lumamig eh so baka tama cya heheheh)....2. tinangal ung filter sa harapan bago mag evaporator (this is the 3by3inch filter)....3. we paralyzed the fresh air effect by sealing the vent which goes thru behind the right side headlight in order to minimize pollution sa evaporator....we were just reminded to check and clean the evaporator every six months (no problem at all with me). Now, even at the peak of the heat level 1 lang ang ginagamit. Sa likod naman level 2 lang ok na.....so for info to others hope this will also help you later....thanks and more power!!!
- May 2007
- 4
May 29th, 2007 03:41 AM #5Hi there Bro, Here's another noobie with the same problem. Just recently acquired a 92 L-300 versavan and im' encountering the same problem with regards to the air-con of our ride.
I would highly appreciate if you could share the name, address,and contact no. of the aircon shop where you had it fixed so i can have my ride checked. Thanks and more power.
- Apr 2007
- 11
May 31st, 2007 10:54 PM #6Address of the Aircon Repair Shop is.....Narra St., (near back gate), United Hills Village, East Service Road, Paranaque City.....i lost the contact number but will get it and post it perhaps tmrw.....catch you later guys....regards
- May 2007
- 4
June 2nd, 2007 08:53 AM #8
- May 2007
- 4
June 4th, 2007 02:01 AM #9Lui, Thanks for the reply.Ok lang sa akin maski sa Manila area pa siya. Ok lang na dayuhin siya basta mag improve lang ang AC ko.He he he. Pasensiya na lang kung medyo desperate.
- Nov 2005
- 457
February 14th, 2008 11:06 PM #10
