Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    Aug 2005
    di kaya mag overflow at lumalabas yung water sa reservior after every ride? try this, dont full up the reservior just half then after you driving a trip check the reservior if it would overflow (be careful the water is very hot) if it do overflow you need to drain it and use a radiator flush. kung ganun parin bka may leak sa baba kaya di mo nakita.
    Sep 2005
    k will check it out. thank u pare
    Aug 2005
    ok lng bro
    Jun 2005
    Quote Originally Posted by jeffishot
    mga bro, napansin ko lang na every time that i inspect my car every morning, i noticed that back up reservoir for the radiator is always half empty. this forces me to re fill it every morning before i drive out. i am sure wala naman leak yung radiator or problem yung cylinder head ko.
    the only peculiar thing that i noticed is that the cap for the back up reservoir is popped out everytime i inpsect my engine as if meron pressure. may duda akong dito tumatapon ang tubig. can anyone help me on this?
    Radiator Cap is set to lift at around 15 PSIG. If the pressure is greater, the cap will release some of the pressure to your reservoir, thats why never overfill your reservoir, leave it half empty for radiator coolant expansion. Anyway, this is a good site to check: http://auto.howstuffworks.com/cooling-system7.htm
Radiator Pressure
