Results 1 to 10 of 287
- Jul 2018
- 38
November 29th, 2018 06:03 PM #1Hello po again. I'm having temperature issues po with my 03 Honda City Type Z. The temperature is getting high so I stopped at the nearest gas station to get water to cool down. There were some bystanders who helped me out to figure out what's wrong with the car. They are saying that the radiator was clogged.
Here's what I know so far:
-the fans are working fine
-I'm not losing coolant and water from the radiator
Sent from my LDN-LX2 using Tapatalk
- May 2011
- 481
November 29th, 2018 10:11 PM #2
- Jul 2018
- 38
November 29th, 2018 10:33 PM #3
- Jun 2005
- 3,774
December 2nd, 2018 12:31 AM #4Maybe its as simple as a faulty radiator cap.
A friend had this intermittent overheating issue on his innova. After a few visit to his suking shop that found no problem, i opened the radiator cap only to see that the spring rusted and fell to the radiator
Replaced it with a new cap. No more overheating
Sent from my MI MAX 2 using Tapatalk
- Jul 2018
- 38
December 2nd, 2018 12:48 AM #5
- Jul 2018
- 38
December 2nd, 2018 01:24 AM #7Actually I did nothing sir. Which really bothers me. I'm not sure what caused it to rise to the point of almost overheating that's why I'm trying to observe the car if it would repeat the same thing again, but so far everything is back to normal. [emoji848] But I'll have my mechanic to have a look at it, may be its just a faulty radiator cap or a water pump problem. I'll let you know once I have figured it out.
- 54,286
December 2nd, 2018 01:30 AM #8perhaps it is the fan.
it may be rotating, but it is not rotating as fast as it should.
if one drives long enough, the coolant will overheat.
i had problem with my sentra before. the fans were working, but when i compared the volume of air the old ones were pushing, to the amount of air new fans would push, i replaced my "still-working" fans. that solved my overheating problem.
another possibility is clogged radiator tubes.
but i finally got to the fans, after ruling out the other possibilities.
it was a tedious process spanning almost a year.Last edited by dr. d; December 2nd, 2018 at 01:44 AM.
- Sep 2018
- 77
December 7th, 2018 12:45 PM #9
[QUOTE=ice15;3387274]medyo disappointing itong Sealion 5 No front sensor either Manual Seats...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
