Results 1 to 6 of 6
- Mar 2010
- 23
March 25th, 2010 11:43 AM #1-wen car starts has normal temp then it increases hanggang magkalahati cya.d naman apektado yun takbo ng car pag ganun nangyari inooff ko yun aircon then mdyo bumababa yun temp nya.dti kase kahit mainit yun weather d umaabot sa kalahat yun temp.
kahit pag gabi d ko na binksan yun aircon at travel ko mula sta mesa to MOA almost half na yun car temp nya.connected din kya kung may problem sa electrical kase pag lock unlock ko yun door central lock cya gumagalaw yun sa car temp kahit gamit ko yun signal lights/hazard light gumagalaw un car temp kahit minsan pag tapak ko sa brek pag half na yun car temp umaakyat yun car temp nya may coolant yun car minsan pagcheck ko sa may reserve na may coolant mainit cya (pag travel time is 12:00nn) pag gabi d naman ganun.d ko kase sure kung may bara lng yun radiator.may kakilala ako ganyan din travel time nya magallanes to MOA 1/4 lng yun temp ako minsan kahit ganun lng distance maghahalf way na yun temp anu kaya problem?
March 25th, 2010 12:09 PM #2
baka electrical problem yan sir, nagfla-fluctuate ang kuryente pag may umaandar na device.
anung kotse ba yan sir and yr model?
- Mar 2010
- 23
March 26th, 2010 11:58 AM #393 lancer EL yun kotse.pag naka on yun radio ok naman pag naka signal lights lng o hazard saka pag gagamitin yun central lock
March 26th, 2010 02:41 PM #4
may electrical disruptions yan sir. check for faulty fuses and wirings. else, check your alternator charge load and your battery load. any other mods that uses heavy power loads?
- Mar 2010
- 23
March 27th, 2010 12:37 PM #5napalitan na alternator ko and vattery is ok just change the fuse.ang hindi ko pa nagawa is pacheck yun wirings....feeling ko rin sa wirings siya.thanks for the advice
- Jun 2008
- 1,741
March 27th, 2010 01:31 PM #6The same car ito sa isa pang thread mo? I suggest merge mo na lang para hindi hiwa-hiwalay ang sagot namin.
Tulad ng sabi ko sa kabilang thread, check mo muna ang electrical system. Kung bagong palit ang alternator at battery, na check ba kung normal ang voltahe & amps? Parang under rated ang alternator ayon sa mga sinasabi mo. Dapat palaging above 12 volts (about or little above 13VDC typical) at ang current rating ng alternator ay equal or more than the replaced unit.. Also check wirings for short/ground problem. Good Luck..
