Originally Posted by
badkuk
update lang...
good news is, nakabili ako ng surplus motor this week. bad news is, apparently the first ae92s that came to RP way back in '89 use a different aux fan/motor -- mas maliit siya compared to the one i got.
to make matters worse, i got adventurous and tried to "modify" the stock aux fan frame, para kumasya ung motor. later i found out that i couldn't use the original fan, since sumasayad ung new fan sa base, and the blades were a lot bigger. hayyy....
so i guess i'll be go aux fan hunting again this weekend; imho my options would be
1.) to find a similar/carbon copy aux fan(malabo imho),
2.) check if the newer aux fans will fit in my ride(tingin ko malabo din),
3.) somehow modify any aux fan i can find para kumasya sa ride, or
4.) buy replacement ($$$$)
i'm leaning more towards #3 right now; if by sheer luck makahanap ako ng compatible fan, i'm thinking i'll be having the same problem again in a few year's time
anyways, just for reference, i removed the passenger side headlight and the metal thingy on the center of the grill(where the hood latch is) before you can take out the fan.
